#29 |
![]() Drives: 2001Camaro Z28 Join Date: May 2009
#30 |
Drives: '14 Jetta 1.8, '19 1SS Join Date: Mar 2010
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
yea most of these axelbacks are pretty pricey not sure why i have the afe power one and mine was $1600 retail lol
full catback is $2100
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
https://youtu.be/sEqktJRy97g
Here’s my Borla ATAK catback with npp.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#33 |
thanks guys those do sound great
#34 |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
Here the AWE Touring catback before cam:
https://youtu.be/Q57IBRT05jE After cam: https://youtu.be/RKXxYVWNB3A Procharged: https://youtu.be/XWzus1s1v-o Driving around before Procharger: https://youtu.be/5c3CLh1mMTs Sent from my SM-G955U using Tapatalk |
#35 | |
![]() Drives: '18 5.7 RAM 1500 18' 1SS Join Date: Jun 2009
https://www.borla.com/products/camar...t__140280.html https://www.borla.com/products/camar...t__140690.html
JRE Tune
#36 | |
You listed a 6th gen ATAK system that is 3”. Apples to apples indeed. ![]() A 5th gen 2.5” ATAK catback 140356 from Juiced is $1250 This is what Borla suggests on how to build a catback per this post: https://www.camaro6.com/forums/showp...64&postcount=1 Get the 6th gen 2.75” ATAK dual tip axleback 11923: $793 Get the 6th gen non-AFM midpipe 60607: $573 Total is $1366. That’s only $116 difference. At MSRP, 140356 is $1442. 11923 and 60607 is $1637. Difference of $200. But please tell me you’re not buying at MSRP because I’d have to laugh at you even harder. With the discount codes that Juiced will give you just for asking, the difference comes out to right around $40 between the 5th gen system and the 6th gen one.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata Last edited by enzia35; 09-26-2019 at 02:32 AM. |
#37 | |
Your just moving the goal post everything your proven wrong. This demonstrates that your just dishonest. Discount codes? GTFO. Next you will say some BS about by used its cheaper. Its simple stupid: Many 6th gen systems cost up to double of the 5th gen and there really is no good reason for it. Also, your example illustrates more of my points. 1. You have to cut your exhaust. That adds more cost. 2. this is not a bolt on. But since your so smart and always right this should be easy for you: Find a 6th gen 304 true bolt on 3" system w/mufflers new for less than 1200 or less. Go ahead and prove me wrong. I do not think you will even try. You will probably deflect and claim victory.
JRE Tune
#38 | |
JRE Tune
#39 | |
JRE Tune
#40 | ||
Here’s the relevant quote from lisa@borla from my post above: Quote:
catback 2.5" 304 stainless steel No AFM No NPP dual tip $1250 Borla 11923 + 60607: catback 2.75" 304 stainless steel No AFM No NPP dual tip $1366 Similar enough? Good. Again, it's not the exhaust company's fault that GM decided to use a one piece catback system. You're absolutely right though. There are no 6th gen 3" T304 catbacks for <$1200. But to say many of them are close to double the cost is straight up lying. The biggest disparity I see on Juiced's site is maybe the Corsa at $600 more vs the 5th gen system. That's not double the cost though. Maybe math isn't your strong suit. Nor your shopping skills: posting/comparing MSRPs, not looking for codes, not looking for a good vendor. I wouldn't buy an exhaust used personally. There's lots of good vendors here, support them.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata Last edited by enzia35; 09-26-2019 at 10:10 PM. |
#41 | |
Even the axle backs are 50% more. You have offered nothing to refute this. 6th gen setups, on avg, are significantly higher price up and down.
JRE Tune
#42 | |
On a side note my shopping skills would beat on you like a rented SS but that is not the point.
JRE Tune
