Old 10-15-2025, 07:13 AM   #29
Camaro ZLE 2021
Drives: Chevrolet Camaro ZL1 1LE
Lugojf
Where did you bought this kit with the hose and OEM fitting?
Thanks
Camaro ZLE 2021 is offline   Reply With Quote
Old 10-20-2025, 07:18 AM   #30
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
Originally Posted by Camaro ZLE 2021 View Post
Lugojf
Thanks
Our kit comes with the SC to bottle hose as part of the kit so you remove the check valve and the 90º fitting that will cause the hose to kink trying to make the sharp turn. Ours also comes with the proper 5psi cap which the Edelbrock comes with the Ford 16psi cap which is three times what is needed for a low-pressure system. This means, this "expansion tank" is not going to allow the bubbles to transfer properly to the tank, but keep them pressured in the bricks if the system is under high pressure. Our system also has the option of a brass ball valve to bleed both the SC Bricks and/or the front mounted heat exchanger if you have one with a top tank fitting installed like our HX has.
Video description of how the expansion tank works and the reverse flow
Patriot Motorsports USA is offline   Reply With Quote
