#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
It was a good thread, but now
#30 |
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
HaHA!
#31 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
#32 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
Do you think the ZL1-1LE is the same or less driveable on regular roads?
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#33 |
If you were even on the Best Track Times list maybe I'd listen to you...
Comfort and driveability does not equal performance FYI |
#34 |
wow...
someone doesn't have an ego or anything.
#35 |
![]() ![]() ![]() ![]() Drives: 1LE Join Date: Sep 2017
TTT
#36 | |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
Driver fatigue will severely impact lap times and repeatability, decision making abilities, and many other factors while on track. A well sorted car with good drivability characteristics for the environment will absolutely reduce this. Additionally, a high degree of drivability and adaptability from the vehicle will make for faster cornering (I wonder why Ferrari has that 'bumpy road' button? hmm) as well as smoother transitions which impact overall laptimes greatly as well. Professional racing teams also go to great lengths to make drivers as comfortable as possible in the conditions, which contributes to their repeatable performance and ability to extract the most from the vehicle. So yeah, you're absolutely dead-ass wrong here. FYI. |
#37 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Bump: Updated the stats I posted on page 1 after speaking to a BMR rep.
#38 |
![]() Drives: Honda S2000 Join Date: May 2019
Where are you guys buying your hotchkics front sway bar? I'm looking to add one to my 18 1le for BS autox.
Thanks Eric |
#39 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Phastek has Hotckis and BMR. https://www.phastekperformance.com/2...des-s/1389.htm
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#40 |
Thank you, looks like the hot. Bar is adjustable what setting are 1le guys running in BS? FULL STIFF?
Thanks |
#41 |
#42 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I came across this post about the Hotchkis bars.
https://www.camaro6.com/forums/showp...4&postcount=19 Poster mentioned his 2SS MRC NON-FE4 car was used for the development of the Hotchkis bars. If this is correct, then everything mentioned about their stiffness being based off the FE4 (SS 1LE and ZL1) bars is incorrect. Full thread: https://www.camaro6.com/forums/showt...04#post9654104 FWIW, I'm running the Hotchkis front full stiff and BMR rear full soft and this combo worked great for me at my last track day weekend.
"KEEP THE FAITH"-Fbodfather |
