Old 01-05-2020, 09:55 AM   #29
BlueShadow
Drives: 2019 Chevrolet Camaro 2.0T 6spd
Originally Posted by Tracerz View Post
From someone who actually competes in Time Attack, I hope you see this. Overall I like the design, but I’d like to recommend a square opening right above the tire , it’s the high pressure zone that many of us cut out, and would be the most effective option. The design your currently showing is often represented on budget builds, most pop the fender loose and add a spacer, but it’s much less effective
Need more aero and time attack/ track community, like where your head is at, this is just my 2 cents
It would be nice if we could get two versions of it. One with no vents and one with vents. Track racers and some aesthetics people will want vents while other aesthetics people (like myself) might not want the vents. Maybe if someone orders a WB kit from C7 they could specify if they want vents or no vents. If someone wants vents then C7 could cut out holes and put in a plastic/abs insert of some sort that has the vents. It could be attached with screws or something. That way they dont have to do two different molds or whatever for two different products. Or maybe they can make it an option for the customer to cutout the hole and install the vents on their own which would save them the time/work.
2019 Camaro 2.0T 6spd
BlueShadow is offline
Old 01-07-2020, 05:34 PM   #30
C7 Carbon
C7 Carbon's Avatar
Drives: Camaro
Thanks for the input, we'll take notes and share this with our design team
C7 Carbon is offline
Old 01-07-2020, 08:15 PM   #31
Tay
Drives: 1985 Oldsmobuick
Originally Posted by C7 Carbon View Post
Here is one of the last teaser pics that we have of the kit before we made the final changes
This kit, is really unique because it is a bolt on wide body. You add the front splitter and extensions that then bolt into the wider fenders.
So in order to run the fenders, we also have to run the front lip?
What id we do not want the front lip?
Tay is offline
