#29 | |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
It will fit a Camaro, not a Corvette - I'll post more details as they become available. |
#30 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
#31 |
![]() Drives: 2018 Camaro SS Join Date: Sep 2009
Looking forward to the cfm airflow chart comparison of the Magnuson and Edelbrock 2650 with port injection in the mix.
#32 |
The supercharger performance won't be any different than what has already been provided. Its a positive displacement device - the CFM of the device is controlled by the inlet conditions of the supercharger rotors.
#33 |
Petro-sexual
Is this the hotrod model that was installed on Guitarmageddon's ZL1? Or is the 2650R that you installed on your C7 capable of supporting port injection? I'm only curious, because I'm not understanding the logic of adding a stand-alone fuel system, now, when there are DI systems capable of doing the same thing, for near the same price, using OEM PCM-control and such, but to each their own. I'm just curious over the comparison/interest from others.
#34 |
standalone lets you inject meth which has a large tolerance for max rich HP, basically, you can pour the stuff into the engine and it is more like a steam engine as some of the increase in HP is in part due to the expansion on the liquid (aka steam engine), more total joule content, and lastly more phase-change cooling. So at this range, you can never do as well with just DI. I went to DI just because on a pure street engine, I felt it was a more dependable, simpler and turn-key setup. But a race car or 3/4 race car... dual inject with meth is very advantageous.
https://www.fuelfreedom.org/hot-rod-...love-methanol/
#35 | |
#36 |
I can assure you with cam lobe the above will support just about any HP that anybody here is running on a street car. So you might want to retract that. The OP is talking about a street blower. I have no opinion on what a race car needs, as I have always contended that any race car needs cubic $$$$ period, plus it is completely off-topic, to what this guy is tossing on an otherwise stock engine. Once again 30% injectors, pump and lobe will have enough HP to BLOW UP ANY STREET ENGINE PERIOD.
#37 |
Petro-sexual
Thank you both for the insight
#38 |
His Zl1 is a Gen5 LSA 2650 Jackshaft with 112 NW TB
#39 | |
#40 |
My best friend is building a forged, ‘18 3.0 Whipple GT with fuel upgrades. It’s a tough thing to be competitive with what he is spending. It’s gonna take a lot of extra on my side to even be close to his car. My post chronicle the extreme but I think it will take ever bit of that.
#41 |
@viurniel
The eForce build that is well documented on the ZL1 sub forum has FIC 30%, Pump, Cam, heads, etc.. and it's still not breaking 'safe' engine levels...
If I was limited on budget, I rather add the secondary port injection and be done with it, it is actually a much easier job IMO than a cam swap, can be cheaper, and it is easily reversible. Looking only at cost: Port Injection Kits (lets go expensive & pick WeaponX)= $5K Or PUMP, Injectors, Cam = $6250 - $6750
Also, port injection as mentioned before is great for adding meth to minimize heat soak. Everything has pros and cons, I prefer to have it all: get a cam and port injection. |
#42 | |
