Old 06-28-2019, 03:50 PM   #29
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Originally Posted by JD2018_ZL1 View Post
Thats amazing for a car off the dealer lot with a warranty.
The second you tune it the warranty goes buh-bye.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 06-28-2019, 06:45 PM   #30
siggy_30
Drives: Jeep Wrangler
I love seeing this comment on car forums. Makes me smile.
siggy_30 is offline   Reply With Quote
Old 06-28-2019, 07:04 PM   #31
JonDaddy82
JonDaddy82's Avatar
I'll be more specific then.
The warranty in regards to the power train.
Better?
Old 06-28-2019, 09:05 PM   #32
BlaqWhole
Drives: 2017 Camaro ZL1 A10
It is absolutely true with Dodge.
Old 06-29-2019, 10:35 AM   #33
trueraiderfan17
Drives: 2018 ZL1 A-10
Originally Posted by Fraxum View Post
I was at Atco last Friday a black A10 ZL1 was running 10.0s with:
Tires
Bigger TB
Ported stock SC
Small pulley
Meth
E45
Voltage booster
LTs
tune
Pretty mild build to be that fast and close to being as fast as you can go without a cage. Why do people go bigger? But stock hellcats are faster than ZL1s.
What the heck does a voltage regulator have to do with hp? I have never heard of this I guess.
trueraiderfan17 is offline   Reply With Quote
Old 06-29-2019, 11:13 AM   #34
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
Higher voltage to fuel pumps increases their output.
Higher voltage -->More fuel --> more power
viurniel is offline   Reply With Quote
Old 06-29-2019, 12:03 PM   #35
I think "less voltage drop [at WOT] --> more fuel --> moar powa" would be more accurate. Quote from the JMS Chip & Performance website:
"The JMS PowerMAX® provides the highest continuous voltage and amperage output without noise, and is available in true 40-amp and 80-amp input fuse configurations. Another industry first includes the ability to choose how to enable the FuelMAX V2 units voltage-boosting output."
Old 06-29-2019, 12:43 PM   #36
trueraiderfan17
thanks guys!
Old 06-29-2019, 02:28 PM   #37
siggy_30
It is absolutely not. There are laws against this. You put a smaller pulley on your Chally; the radio breaks. You’re telling me Dodge would deny your claim?
Old 06-29-2019, 10:50 PM   #38
Blaq must have meant the powertrain warranty, and that is shot if you tune the engine. Radio falls under bumper to bumper.
Old 06-29-2019, 11:50 PM   #39
Rapidfire
Drives: 2018 A8 ZO6 black rose metallic
Originally Posted by Rapidfire View Post
Drag radials and a tune will put you in the 10s
Add some skinny's to the front also or you'll sway .. plus it'll cut about 50 pounds
To much traction in the front will pull you all over the track.. this is something that isn't mentioned enough..or match the compound to the rear..
Rapidfire is offline   Reply With Quote
