Old 06-18-2019, 11:11 AM   #29
Marco Falcone
Marco Falcone's Avatar
Drives: 2018 2SS Convertible MBM/Kal
This sounds awesome. I love my 18 2SS vert, but that lag...
My car is bone stock except for a Range and a Fuse 51 pull. (It has an untouched OEM throttle body and intake manifold.)
If this all by itself will really improve the lag and it doesn’t throw codes, I’ll be buying one when I get back from vacation in a couple weeks.
Thanks Soler!
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note:
2013 Caprice PPV. (“Company” car.)
1998 Cadillac STS
1996 Impala SS
1969 Cadillac DeVille Convertible
1993 Corvette
1991 Mustang 5.0 LX
1973 Alfa Romeo Spider
1986 Mustang GT T-top
1964 Falcon Sprint Hardtop. (First car, still have the key!)
Marco Falcone is offline   Reply With Quote
Old 06-18-2019, 11:40 AM   #30
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Originally Posted by rayhawk View Post
My car has a hesitation at about 1800-2000 rpm. It's most noticeable in traffic, just trying to maintain say 30 mph in 3rd gear, it is really unsteady. I can't find anything wrong with the car, no misfires or anything. Any chance this TB would help with that? My car is completely stock.
rayhawk, we are not familiar with this particular issue, but the design aims to reduce hesitation at part throttle in general while optimizing flow at WOT as well.
Yes, I'd think it is worth trying. Worst case scenario is that our TB does not solve the issue, in which case you'd get a full refund, free shipping both ways. You'd be only putting the 15 minutes it takes to replace it.
Thanks,
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-18-2019, 11:49 AM   #31
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '18 1SS 1LE
Just ordered mine, interested to feel the difference compared to the Mamo PTB I'm currently using.
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2
Chocolate Apocalypse is offline   Reply With Quote
Old 06-18-2019, 11:52 AM   #32
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
Putting this on my list to get. I drive a lot in lower ranges (10-20 MPH) daily and I get lunges, rough spots while trying to maintain speeds in my manual. Something like this is what the doctor ordered. It will have to wait for awhile as the car will be in storage for a few months and I don't have time to change out parts right now. But subscribed to the thread as a constant reminder to order this when I am ready!
red_johnny is offline   Reply With Quote
Old 06-18-2019, 12:02 PM   #33
Jsreo
Drives: 2017 2SS Manual
Please post back on your observations. I also have the Mamo PTB & would like to know if any change would be worthwhile
TIA
Jsreo is offline   Reply With Quote
Old 06-18-2019, 12:04 PM   #34
Originally Posted by rlarsen462 View Post
If I send in a Weapon-X PTB for the Rework program, will it be identical after rework to a new OEM unit that you've worked?
If so, I'll be sending mine this week.
Thanks.
That is the point of the rework, to match the response curve of our design, identical (+/-10%) in performance, but not identical in geometry. Let me explain why and the possible outcomes.
That is, we have noticed some inconsistencies with ported throttle bodies, especially those that have been hand ported or ported in a way that is not repeatable. In other words, we cannot assume they are all the same and that the same rework will end up with the same results. We rather take them in a case by case basis. One of the possible outcomes is that we'll have to send you one of ours at no extra charge to you.
Features we can assure you would be identical and non-existing on your PTB:
- Half-shaft (Makes effective bore diameter 91 mm minimum)
- Countersunk screws, flush on other side, locked and peened (reduce pressure loses)
- Blade modification (reduces pumping loses)
- Flow area increases right-off idle, inlet and outlet (improved response)
Note: We have not inspected a statistically significant number of the PTB's in question to say they are inconsistent dimensionally, but it is a possibility.
Old 06-18-2019, 12:18 PM   #35
Originally Posted by ssmike View Post
I have a Cold Air Induction CAI and it uses a TB spacer with a small spike to eliminate the whistle sound. Will I continue to use the spacer with this re-worked TB or not?
I don't see why not. It will fit, and as long as it is not obstructive it shouldn't affect performance.
Old 06-18-2019, 12:27 PM   #36
Originally Posted by USAFS197 View Post
Have you guys performed any of this porting and testing on the LT5 95mm throttle body?
Working on it as we speak. We anticipate that it would need calibration. Stay tuned...
Thanks,
Old 06-18-2019, 12:43 PM   #37
Full Fledged Member
Drives: '18 1SS 1LE
TIA
Absolutely! 👍
'18 1SS 1LE - DD
Old 06-18-2019, 01:34 PM   #38
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
Is there a discount code for forum members?
lgarrison34 is offline   Reply With Quote
Old 06-18-2019, 01:43 PM   #39
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
Originally Posted by z28pat View Post
I’m also very tempted because driving a stickshift I can feel the lack of throttle response and can’t blame it on the tranny. Makes it hard to modulate pedal pressure.
Exactly why i dropped the coin for one this morning.... i like to drive on tight twisty mtn roads and the non linear response keeps me from being smooth on corner exits since i dont consistantly know what the car is going to give me at part throttle applications.... hoping this cures it.
Racerman27410 is offline   Reply With Quote
Old 06-18-2019, 01:54 PM   #40
Mr.DoubleB
Drives: 2018 1LE/LS
Will this work on the V6 LGX engine?
Mr.DoubleB is offline   Reply With Quote
Old 06-18-2019, 02:02 PM   #41
CamaroChriSS
CamaroChriSS's Avatar
Drives: 16 1SS M6 Black -previous 00 Z28 M6
Link to order and cost? Thanks!
CamaroChriSS is offline   Reply With Quote
Old 06-18-2019, 02:08 PM   #42
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
Please let us know how this turn out once you’ve installed it , seems like a straight forward install but pictures would help
Thank you
z28pat is offline   Reply With Quote
