Old 07-30-2019, 01:14 PM   #29
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
Originally Posted by Vtor_ZL1 View Post
If you're looking for seat time, MSNE has Test & Tune in morning - basically limited attendance event in morning and then Autox ( points event ) starting about 2pm.
In regards to quality of imported coilovers, ran BC coil overs on last car for years, no failures. Little over year on DSSV, both fronts have been replaced due to "clunking" so yeah so much for $2K/each shocks.
KOni still MIA ?
My MCS are pimp.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 08-06-2019, 06:02 PM   #30
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Originally Posted by Chris V View Post
8/4.
NNJR SCCA and MSNE are always at Met Life.
My car will be there on 8/4, but I'll be camping on the AT so stop by and ride along with Jeff if you want. My car is on MCS.
I was at scca and ran on 8/4 but the only camaro i saw was jeremys 2019 1le.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 08-06-2019, 06:06 PM   #31
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
KOni still MIA ?
Thats wild, 2 failures? Yea i was drained after working heat 2 in that sun. I couldnt hang around for the msne event. I need to get on thunderbolt soon.
Old 08-08-2019, 08:51 AM   #32
Chris V
Chris V's Avatar
First car in the video here:
https://www.facebook.com/723331255/v...1csX4GKr9UWCgc
You (I think) appear around 1:45.
Old 08-17-2019, 08:18 PM   #33
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Yup that's me lol
Old 02-24-2020, 06:32 PM   #34
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
so how did these work out? lol still on the car or did you junk em?
Old 02-27-2020, 07:12 PM   #35
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Still running solid. No leaks or weird noises. I changed rear spring rates for something a little stiffer. Thats it, idk about mrc but it blows base shocks and lowering springs away lol. Ready for track season
Old 02-28-2020, 10:48 AM   #36
kropscamaro16
nice! i finally got my setup all worked out also what springs did you change them to?
Old 03-07-2020, 08:43 AM   #37
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Brought the rears up to 14k. It helped cut in quite a bit. Im gonna run a few events like that then look into sway bars
Old 11-20-2020, 01:59 PM   #38
Waxenate
2019 2SS
Drives: 2019 SS
I put a set on and so far that feel about 100 times better than the Eibach springs. Ride is better and cornering is ridiculous. Not a track guy just want to be able to set my ride height without giving up too much comfort. Anyone have settings they like and would share. Would be a good discussion!
Waxenate is offline   Reply With Quote
Old 11-20-2020, 09:34 PM   #39
Baddawg53
Drives: 17 hyper blue 2SS M6
I just installed my set, 8k front 12k rear swift springs. Definitely kind of a pain getting the ride height perfect side to side, especially on jack stands in my garage.
Alignment set for Tuesday, track day next Friday so we'll see how they are next week. Right now I have all 4 on the middle setting, figured it was a good place to start.
Baddawg53 is offline   Reply With Quote
Old 11-22-2020, 10:56 AM   #40
Waxenate
2019 2SS
Drives: 2019 SS
8k, 12k? I don’t know a ton about suspension...
Old 11-22-2020, 12:56 PM   #41
Baddawg53
Spring rates.
Old 11-22-2020, 05:10 PM   #42
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Originally Posted by Baddawg53 View Post
Spring rates.
Well, the rates are presumably kg/mm, but the BC site is unsurprisingly unhelpful when it comes to "specifications." 1 kg/mm = 56 lb/in. So an "8k" spring is 448lb/in, 12k is 672 lb/in.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
