#29 |
![]() Drives: 2018 1LS Camaro Join Date: Mar 2019
If you cant get in reverse just let the clutch out a little to the gear moves and it will drop right in.
#30 |
![]() Drives: 2018 Chevy 1LS Camaro Join Date: Jan 2022
Did anyone figure out why that happens? I have a 2018 v6 ls and for some reason my reverse won't let me get it in some times as well. I'm fully stopped clutch all the way down I can feel it go past the lock out but then it's a wall. This isn't my first manual and this has never happened before but none of my previous cars has been chevy or that new I'm use to the 1990s cars. If anyone knows the answer that would be awesome if not I'll probably be selling it soon nothing but problems with this one.
#31 |
![]() Drives: 2022 Camaro 2SS 1LE - Shadow Grey Join Date: Jan 2022
I’ve almost exclusively driven manuals for the last 20 years - quite a few performance cars from multiple different brands.
I’ve noticed this on almost all of them - you get used to double clutching for reverse. I wouldn’t worry about it. Always seems more apparent when cold. For example - Honda make arguably the best manual transmissions around and they are well known for the reverse crunch |
#32 |
![]() Drives: 2018 Chevrolet Camaro 2LT Join Date: Mar 2019
First of all don't listen to all the SS folks as they have a different transmission with the reverse on the right where is should be. Since with our transmissions the reverse is on the left you have to apply a fair amount of force to get it into reverse so you don't do it accidentally when finding 1st. I find I tend to slap my gear shifter which does the job. Not fully engaging when shifting up into R is normal as you're physically moving a gear to mesh with another where as all the other gears are always meshed. If the teeth on the two gears are misaligned is won't go in. Just slightly ease of the clutch to slightly spin one gear and it should go in.
#33 | |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
You have to give the dealer 3 chances to fix it. If they fail, use the lemon law to get a refund or a new car. |
#34 |
![]() Drives: CamaroV6 1LT Join Date: Jun 2022
Hi. Did your problem get resolved. I am having the exact same issue with a 2022 Camaro?
#35 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
If it doesn't want to go in reverse put in first bump it a little, then it will go easily into reverse. The v6 manual transmission is not the easiest to use , but over time I have come to like it.
#36 |
![]() Drives: 2022 1LT RS 2.0t/6spd Join Date: Mar 2022
My preference is to always park the car in reverse. That takes care of the cold reverse engagement issue for me. The occasional time it happens after that slightly engaging the clutch allows it to pop in as many have noted. I saw the same thing occasionally going into 1st initially but that has gone away with miles.
