Old 06-10-2019, 12:16 PM   #29
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
I was thinking if he ordered it and took the kit to speed inc. Weapon X claims plug and play. Speed inc I’m sure has A/C equipment to deal with the freon.
Not sure if there’s a big price difference . I haven’t looked that closely.
Old 06-10-2019, 02:40 PM   #30
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
I inquired about this kit from CSP on their website and they offered install help when I take it to my local shop. Did you buy it direct from FI?
Mcmillion is offline   Reply With Quote
Old 06-10-2019, 03:08 PM   #31
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
We had one of our Engineers testing these a few years back. For road race applications you want to use the Toyota Prius or the Chevy Volt 12v DC AC compressor. Runs with no load on the engine and no WOT shutoff. You can also rig a solenoid to keep the compressor engaged during competition mode.
These, if installed properly, will maintain 40-50*F below ambient air temps at a fraction of the overall weight of a ice box system. I have not studied the WeaponX system, but they all are not that complicated to install and when done correctly are awesome. Keep in mind, at 115* IAT 1-2 degrees of timing will be pulled, at 150 3-5, and above as much as 8-10 plus. On a stock ZL1 we saw a 40 WHP gain over the stock ambient air temp system. And total weight added as app 12#. But that was 5-6 years ago. On a 1000 HP build it was not as effective, but in the 1/4 mile started at 43* when staging, at the stripe it was still below 70* and by the time we were back in the pits it was back down to below 40*. That was with the AC comp disengaging at WOT during the run.
It takes less than 3 minutes to go from 120* IAT-2 to below 45*F.
We don't sell or make them, just contributing the testing done years ago.
Elite Engineering is offline   Reply With Quote
Old 06-11-2019, 06:43 PM   #32
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
I decided to just sell it.. if anyone’s interested please let me know.
Procharged 2018 ZL1 A10
2018 2500HD Duramax
TripleBlkZL1 is offline   Reply With Quote
Old 06-11-2019, 06:52 PM   #33
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I'm interested what do the directions look like.
Old 06-11-2019, 07:19 PM   #34
TripleBlkZL1
PM sent
2018 2500HD Duramax
Old 06-11-2019, 07:31 PM   #35
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
Thanks for the info. Did you guys do any testing on the road course with an electric a/c compressor?
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 06-11-2019, 11:01 PM   #36
Scottyz
Scottyz's Avatar
TTT. Im curious for an answer to this question also.
Old 06-12-2019, 05:35 AM   #37
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
I am in the process of installing my stage 2 Forced Induction Interchiller & hope that all goes fine . I have it on my 2012 ZL1 & that was with hoses already crimped and ready for installation not like this one .
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 06-12-2019, 06:47 AM   #38
parish8
Drives: 17 SS a8
Ahmad
What parts do they add to make it a stage 2? Guessing a 2nd Freon/fluid heat exchanger?
Old 06-12-2019, 05:02 PM   #39
ramairroughneck
Drives: 2018 Camaro SS
My take is the stage 2 adds a solenoid and inside switch to block the flow of freon from circulating through the cabin. Nothing across the evaporator, everything is going solely through the chiller. I would guess same chiller and no extra HX
The comp solenoid allows you to run the AC system in 2 modes:
1. Cabin and Chiller
2. Chiller only (race track safe)
In chiller only mode you are able to get colder intake temps and you will pass tech inspection at your race track as condensation is then unable to form on the cabin evaporator and you are then allowed to use the AC system on the track, as long as your intercooler lines are also insulated to not drip condensation.
The solenoid is controlled by a simple ON/OFF switch inside the cabin.
ramairroughneck is offline   Reply With Quote
Old 06-12-2019, 05:31 PM   #40
alssiri
alssiri's Avatar
Didn't open the box & had to send it to the garage for the install , I think you are right & will confirm it when i go to the garage.
What you are talking about is the competition & street mode .
2012 ZL1 A6 (SOLD)
Old 06-12-2019, 05:38 PM   #41
parish8
Drives: 17 SS a8
yeah the competition and street mode valve is part of the base kit.
Old 06-13-2019, 01:59 PM   #42
Want1
Drives: 2017 Camaro SS 1LE
By the way, is there anybody in Phoenix who has one of these installed, and is working as it should?
I called a couple of shops regarding installation, and they are saying that these don't work properly in Phoenix?!? They have even uninstalled a couple of them due to that AC not being able to work because of the intense heat?? Which doesn't really make much sense since the manufaturer is located in Australia which is a pretty hot place, also, so... Any insight??
Want1 is offline   Reply With Quote
