Old 03-25-2023, 02:18 PM   #29
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Vigilante375 View Post
Are you asking if the stock ZL1 1LE rim comes in 17s? No. Because that is what this person has.
I don't know if I've ever seen an after market version of them in 17s. 18 is the lowest I've seen over the years.
Yea, I'm wondering if my OEM 19" wheel comes in 17".
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 03-25-2023, 06:05 PM   #30
Vigilante375
Drives: 2018 Camaro ZL1
As far as I've seen over the years. No.
18s are the lowest I've seen from the aftermarket. Since most people who want these type of rims want to go to a road course and not a drag strip. And drag strip people use Welds or similar rims.
As you probably know, you can't fit 17s on the front unless you change to a smaller brake setup but you can fit 17s in the rear without any brake changes.
Old 03-25-2023, 08:36 PM   #31
JSH
JSH's Avatar
Drives: '20 ZLE
I've got a set of 17" bead locks but the local shops stopped selling or mounting them, so I would like to sell them and find a set of 17" wheels like my OEM, and maybe put some Nitto 555Rii P305/45R17 or another R888R on them. This car hates Mickey's.
2020 ZL1LE A10.
Old 03-29-2023, 04:57 AM   #32
samh
Drives: 2018 Zl1
Yes.
5th gen ZL1 rims also fit perfectly. I have a set I use for the road course.
Do you happen to know the tire sizes matching them? Can I go 325's with those rear ones?
Also I'm guessing the speedometer might need adjustment going from stock wheels to 19" Z28s?
samh is offline   Reply With Quote
Old 03-30-2023, 12:19 PM   #33
Vigilante375
The stock 5th gen ZL1 rims are the same sizes as the 6th gen ZL1. I only have used the stock size Goodyears and a 325 will fit but it'll poke out a bit over the rim.
I don't believe going down 1in on a rim will affect the speedo that much but changing tire the size definitely will. Bigger tire will rotate slower so then the speedo will read the speed as lower.
Old 03-31-2023, 10:07 PM   #34
Jaydoubleyou
Drives: Camaro
I actually didn’t know about sharing the rims. Good info. Thanks y’all. Next year Craig straight up clicks off safe on some random new guys for the same thing NERD!! Haha welcome.
19 ZL1 Mosaic Black, M6 like a dude with all the fixins.
10 SS Aqua Blue (Sold)
93 RX7 475rwhp (Sold) regrets there
Jaydoubleyou is offline   Reply With Quote
Old 03-31-2023, 10:39 PM   #35
AZ_1LE
Drives: 2019 ZL1 1LE
Do you know if this wheel comes in 17"?
The smallest you're gonna find for our cars for the most part is a 18" wheel due to the size of the front brakes. Even then, it's hard to find 18's where you're not REALLY close to scraping the outside of the caliper body.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-01-2023, 08:02 AM   #36
JSH
JSH's Avatar
Drives: '20 ZLE
I need a non-bead lock 17" or 18" OEM style wheel for the rear. No other tire comes close to the MT ETS R P315/55R17 or P315/50R17 in height and circumference. Their 18" would work too.
I assume the rear calipers are not an issue.
I own 17" bead locks but most shops won't touch them.
2020 ZL1LE A10.
Old 04-01-2023, 10:30 AM   #37
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
Originally Posted by Stephen12ZL1 View Post
ZLE wheels on a ZL1 with Eibach springs and a 5mm spacer up front.
That looks fantastic.
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
Old 04-01-2023, 11:54 PM   #38
clg82
Drives: 2020 Camaro ZL1
Got some ZLE take-off's mounted up yesterday. Love 'em! They'll be for track duty, but it's fun having them on the car for a few days.
Did you have to shave down the front struts to run those?
Old 04-01-2023, 11:54 PM   #39
clg82
Why the 5mm spacer up front? And what brand did you go with? You track the car with those spacers?
