01-30-2019, 11:35 AM | #29 | |
These are amazing! I used them on my 2010 Camaro SS show car for about 3 years.
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
01-31-2019, 11:48 PM | #30 |
Drives: ZL1 1LE Join Date: Aug 2018
02-01-2019, 08:14 PM | #31 | |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
in the slots was making me think those fittings may not be as tight). But looks like Galvanized (G90 dip) against aluminum will be fine. MACs TireBlock Straps plus the low idler strap (two eTrack fittings with 2" strap between). Just-in-case I want to take it a tad lower to the eTrack rail. BTW...thanks for checking!
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
02-03-2019, 09:32 AM | #32 |
Drives: 2017 ZL1 Join Date: Mar 2017
I use through the wheel straps. Have no issues with rubbing the splitter.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325) Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq |
03-05-2019, 12:44 PM | #33 |
Sooo... Where it ended-up was. Have the Aluma 8220 (20') Tilt trailer, where the tilt section is just a shade over 20', so the total platform is closer to 21'+. The MACS straps, OverTheTire with rubber blocks and e-Track ends. 4-8' sections of eTrack held down with Button Torx Self Threading or Bolt Thru. I used all self threading first, then backed the ones out where I could actually use a bolt/nut setup... Nice part was, the threads where there vs just a drilled hole. (Used similar bolts where a nut/washer could reach on the other side). There is about a 2' gap between the front/rear e-tracks. All threads coated with marine grade anti-seize.
Finally got to us the setup this past weekend up at RoadAtlanta. All I can say is WOW, I could not be happier with the total package as I set it up. And the tilt-trailer is just amazing... Not cheap overall but, what an outstanding trailering rig now!
BobR
03-06-2019, 08:02 PM | #34 | |
Drives: 2018 ZL1 Join Date: Jan 2018
PICS ????? |
03-07-2019, 06:48 AM | #35 |
03-08-2019, 12:35 PM | #36 |
Sorry for the dark pics....
BobR
03-08-2019, 02:38 PM | #37 |
cars leaving the factory have spacers in the front springs and are strapped to the frame. All larger car carriers use frame mounts vs tire straps. You could argue for days which one is "better". Yeah, UHAUL uses tire straps for Joe Homemaker but does that make it the gold standard for strapping a car to a trailer? Frame/control arm strapping crossed has always served me well and I will continue to strap this way. Anyone above that wants their car "floating and rebounding" on a trailer needs to have their heads examined. Even with frame mounts the car is definitely not solid and the suspension still continues to have some compliance.
03-08-2019, 06:14 PM | #38 | |
Drives: 2018 Camaro SS Join Date: Sep 2009
03-08-2019, 07:35 PM | #39 |
Drives: 2019 ZL1 1LE Join Date: Jan 2019
Tire straps are by far the most common, as using frame points is very difficult with the big carriers (angles of straps, rub points, clearances). Every car/truck is different, too many makes/models, the rigging would be extremely difficult if not using tires...tires are easiest (and safe enough to be industry standard).
03-08-2019, 08:27 PM | #40 |
Drives: 2017 Hyper Blue SS 1LE Join Date: May 2017
03-08-2019, 08:33 PM | #41 |
OK...I still see both ways in an "images" search. Thanks for the info.
03-08-2019, 11:02 PM | #42 | |
It did well, but I have the Duramax version. I towed from TX to NH with no issues. The only time it struggled is when I needed to pass while at highway speeds.
