Old 11-05-2018, 05:09 PM   #29
Buckscamaro
Buckscamaro's Avatar
Drives: 2016 ss camaro
https://youtu.be/KI4t3WWiAgo
Here’s the video of the dyno session.
You tube channel:
G's footage
https://youtu.be/VCnanR8qsNg
Instagram: boogieman_racing
Buckscamaro is offline   Reply With Quote
Old 12-05-2018, 09:35 PM   #30
NiteNite 2SS
Drives: 2017 2SS & 2015 2SS Murdered out!
So recently I purchased a *ick performance 95 ported TB.. and I began to have issues with the TB after a tune ....After 2000-3500 Rpm the engine would start to lose power. Has anyone else experienced that? MODs: MSD, Kooks headers, Catchcan, Tune, MBRP exhaust.
NiteNite 2SS is offline   Reply With Quote
Old 12-06-2018, 12:34 AM   #31
Buckscamaro
Mine still going strong. I wonder if it has something to do with tune, maybe talk to tuner about putting stock tune back in to test it out. If it still messing up I would reach out to tick
You tube channel:
G's footage
Old 12-06-2018, 10:47 AM   #32
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
That sounds like it is going to be a tune related issue to me. My car had some problems with the throttle trying to close around 5800 rpm under a wide open pull. It would close off to about 50% for a second then it would open back up all the way.
I am not the tuner, so I can't be much help when it comes to that. But I know we were able to fix my issue with ease.
Matt@Tick is offline   Reply With Quote
Old 12-06-2018, 11:21 AM   #33
Sonny16SS
Tick - How can you tell when the throttle is closing at wide open? via HPTuner scanner? if so, what pid are you looking at?
PS. I have ported 95mm TB as well and my dyno operator said that it looks like the throttle is closing under wide open too.
Sonny16SS is offline   Reply With Quote
Old 12-06-2018, 12:18 PM   #34
Matt@Tick
Matt@Tick's Avatar
Yes, you can see it in a tuning log. But Its pretty easy to feel it happen when it goes from wide open to half open and then back to open.
Old 03-31-2019, 11:25 PM   #35
Warren
Drives: 2013 ZL1
Have any of you checked your idle timing after installing the 95MM TB ? I bet you will be surprised at what some of you will find. example, one car ran and idled perfect but if you look at idle timing it is in the negative, -4 to be exact. put stock TB back on and it idles at 11 degrees.
Warren is offline   Reply With Quote
Old 04-03-2019, 06:57 AM   #36
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
did you adjust it back with tune or did you just leave that...
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned
biker2k is offline   Reply With Quote
Old 04-04-2019, 01:34 AM   #37
Warren
Drives: 2013 ZL1
Haven’t found anyone that can fix it. If you know how please share.
Old 05-15-2019, 12:52 AM   #38
squish72
Drives: 2016 2SS 8AT
Did you figure it out?
squish72 is offline   Reply With Quote
Old 04-13-2020, 07:54 PM   #39
pmoore4321
Drives: GMC Sierra
https://youtu.be/Ca0HYnQ7J7g
pmoore4321 is offline   Reply With Quote
