Old 09-25-2018, 10:44 AM   #29
KirkH
Originally Posted by ToeKnee Sea View Post
I have used Opti-Seal on both my cars recently and like it very much. Great shine and beads water even after two washes and 5 weeks time. Amazon sells it.
Opti-Seal is a great product that has been forgotten with the influx of new coatings and sealants.
Old 09-25-2018, 12:01 PM   #30
SSport16
SSport16's Avatar
Does Carpro make any soaps/wax strippers?
Old 09-25-2018, 12:37 PM   #31
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Carpro eraser.
Or just wipe it down......twice......with 30% alcohol 70% water.
Old 09-25-2018, 01:31 PM   #32
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Which is basically what Eraser is
(it's also a great window cleaner)
S2K+1LE is offline   Reply With Quote
Old 09-25-2018, 03:25 PM   #33
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Eraser is very different than IPA. IPA dissolves wax, Eraser lifts it off the surface and encapsulates it so it can be wiped away. You can also leave Eraser on the surface for a much longer time than IPA as well, IPA will evaporate quickly. IPA leaves some residue on the surface (not much though), Eraser leaves none.
An easy way to remove wax is to spray the panel with APC when doing a normal 2 bucket wash. Do not allow it to dry, or use on a hot surface or in direct sunlight. Rinse well.
Before applying your new wax or sealant, check the panel with a baggie to determine if claying is needed. Wipe panel down with IPA or Eraser prior to adding your protection. This will ensure the proper bond to the paint.
This is why you hear one person claiming their protection product lasted only 2 weeks...…. and another claims 4-6 months from the same product. One was prepped properly and one wasn't.
It's like sticking two pieces of tape on a surface, and one area is completely clean, and the other has dirt on it. Which piece will stick the longest?
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 09-25-2018, 08:13 PM   #34
Markoz28
Drives: 18 ZL1 nightfall grey A10
Jescar Power lock is a great sealant. I loved how easy it was to put on and take off. Leaves the car looking really glossy. I topped it with collinite 845. Pretty sure in about a couple of months im going to do it again but not with the 845. I think the Power lock looks great just as it is.
Markoz28 is offline   Reply With Quote
Old 09-25-2018, 10:21 PM   #35
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Obsessed garage fan?
ninetres is offline   Reply With Quote
Old 09-26-2018, 07:14 AM   #36
Traumamoma
Drives: 2017 SS 1LE Summit White
Forget about Dawn detergent. Use Chemical Guys CLEAN SLATE. Then Carpro Essence. Then Carpro reload. I do this twice a year on a very lightly driven car. In between I will rinse it every couple of drives and spray on Ultima waterless wash diluted to detail spray strength. Dry with MF towel and you are done!
Traumamoma is offline   Reply With Quote
Old 09-26-2018, 07:19 AM   #37
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I have use reload for a year or two and I'm done with it. Too streaky, tricky to put on, a much better alternative is the blackfire SiO2 spray. It applies easier, it comes off easier, and there is absolutely no streaking. Works well with essence too.
Old 09-26-2018, 09:22 AM   #38
SSport16
SSport16's Avatar
Originally Posted by Glen e View Post
Carpro eraser.
I know Eraser, didn't think they had a soap that would strip, just was curious.
Old 09-26-2018, 09:24 AM   #39
SSport16
SSport16's Avatar
I never get streaking with Reload, occasionally from the Reload/Echo QD, I try to mix it on the lighter side than most people do.
Old 09-26-2018, 12:06 PM   #40
VinnAY
Drives: 18 1SS/1LE
I need to review some paper and see what this dealer put on my car at delivery, some kind of sealant that I'm sure I overpaid for.
Old 09-26-2018, 12:21 PM   #41
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
I’m afraid to wash with dawn on my car. I’ll use the other car as a test subject before I do it on the Camaro. I thought about getting clean slate.
ItsChristianInHD is offline   Reply With Quote
Old 09-26-2018, 03:05 PM   #42
ninetres
ninetres's Avatar
Not sure what I’ve been doing right but I’ve never had streaking with Reload.
