Old 09-19-2018, 10:15 PM   #29
Drsagacity
Drsagacity's Avatar
Originally Posted by SDG23 View Post
I know this has been covered, but my goal is 600 to the wheels, nothing crazy but a decent bump up. Will the stock SS fuel system hold up? I hear a lot of numbers but in general I hear 600rwhp is about it for the stock SS fuel system, does this sound about right? Thinking of going with a Maggie 2300, I already have a ported TB and RotoFab dry intake so I'm thinking an 85mm pulley should get me there.
Yep. You are right on the number. You will be between 550-600whp at 7psi.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 09-19-2018, 11:29 PM   #30
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I suggest to upgrade the fuel system. 570-600whp is about Max on 93 depending on dyno. I wouldn't want to be at Max or squeak by on these engines. The issue is rail pressure...especially with PD blowers. They require more fuel on the hit compared to a Centri setup...which can cause a lean spike from rail pressure drop.
Old 09-25-2018, 12:14 PM   #31
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
I agree. On the dyno you can get by but on the street it may run lean. This is probably the number 1 reason why these LT1 motors pop. Tight ring end gaps and lean condition from an inadequate fuel system.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
