#29 |
![]() Drives: '18 Camaro SS Join Date: Sep 2018
Don't they allow street cars to run as well? Have been out of the scene for a while. Just want to make some fun passes on Thurs/Fri, not necessarily run a specific class.
#30 | |
BAMF SS
And as far as letting you run on wed/thurs... I wouldn't know.... I usually go on Saturday and Sunday.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#31 |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
A 10 second slip is not an easy task. I can tell you what I had in my car to run a 10.98 in Nov 2017. The first mod is free...negative DA or as close to zero as possible. You will need good air and really good prep to even have a shot without going full tilt on the mods.
As King said earlier, tuning is key and it is a constant work in progress when you are at the track. Datalogging passes and making adjustments accordingly. Dialing the car in on the dyno is great but the fine tuning happens all at the track. My mods were; Front skinnies At the time I had M/T 305/20's on stock wheels but I would highly recommend going 17's and a lightweight wheel like Forgestars etc. RotoFab with dry filter Ported throttle body Ported intake manifold...I used a stocker but would recommend the MSD Flex fuel kit and e70+ in the tank GM 3.73 diff Lightweight battery (mine is a 21lb AGM) Remove passenger and rear seat Drain the windshield washer fluid Believe it or not those all were my mods iirc. I was lucky enough to record a 10 second pass with the stock exhaust manifolds, all 4 cats, the suitcase muffler with the stock torque converter and the stock suspension. The wheels/tires would take up most of your 2K unless you score a good used set, and add 500? for HP tuners software...which doesn't include the tuning...and plenty of seat time. The other mods people mentioned will help (MSD 95mm tb, headers/no cats or a converter) but if the racing gods are kind to you, it is possible without them. Both Brandon and Troy used a 26" tire setup that seems to work well with the stock converter. Brett and myself had 28" tires but he had a Circle D and I had the 3.73 gear to get me there. I believe I have been the only person to run a stock exhaust system and 20" DR's though.
#32 |
![]() Drives: 2017 Camaro 1SS Convertible Join Date: Jul 2018
The main point of the post was the fact I'm just wanting to do something quick and easy for around $2,000 to get a performance boost. Just got back from LS Fest and saw a lot of what looked like close to stock 6th gens running mid 11 times. But everyone was on DR's. Would love to get to around 11 flat in the 1/4 if it's possible for around $2k. My budget isn't set I just wanna start small before I go big and break the bank and the wife flips out.
17' Camaro 1SS Vert - Plastidip for 50 Hp gain.
