Old 05-05-2019, 11:49 PM   #29
steelheadrob
Tactical Garage
steelheadrob's Avatar
Also you might need to change those switches highlighted in red(refer to the pic) if you have voltage/fuel pressure fluctuations due to the variable rate charging system. changing those will keep the voltage to the FSCM more consistent. Factory is set to 11.6v minimum, I bumped my Camaro and the Vette to 12.5, maximum voltage is 14.0, but you can do 14.6.
Credit to BlueCamaro6!!
I did one quick before and after changing to 15.5 test pull yesterday. I saw a slight improvement but not that dramatic. I will bump the min and max up and trying increasing from 15.5 to 16 this next weekend when I have more time for testing.
steelheadrob is offline   Reply With Quote
Old 05-08-2019, 11:08 PM   #30
steelheadrob
Tactical Garage
In logging the control module voltage at the stock 14.7 fuel minimum voltage setting I am seeing 13.4 for control module voltage. When I increased the fuel min voltage to 15.5 the control module voltage increased to 14.3. I will bump the fuel min volt to 16.5 and log the control module voltage to see where it goes to.
For the guys that have installed the BAP, what are you seeing for control module voltage? 17.5 volts?
Old 05-09-2019, 08:02 AM   #31
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Odd. I'm only seeing 13.70 on my Control Module with the BAP in my HPTuners log. Should that be over 17 volts or is that something that Data logging is not going to pick up?
Dysan911 is offline   Reply With Quote
Old 05-09-2019, 08:43 AM   #32
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I haven't logged mine, but my assumption is you won't see it change at the control module because I believe the JMS taps the wire going to the fuel pump.
Old 05-09-2019, 02:34 PM   #33
TJay74
Has anyone had any luck being able to license the FPCM in a 1LE car? All I see is the CCM module, there is no FPCM when I try to read anything. I am on a Jannetty tune as well using a JMS BAP in the mean time but am limited to E40. I am tackling the HPFP fuel line next as I have read that line has an orifice in it that was cause all sorts of issues with the HPFP fuel pressure dropping.
Also has anyone replaced the HPFP fuel line under the intake with the one that doesnt have an orifice in the line?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 05-11-2019, 10:06 PM   #34
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Is this orifice on the discharge side of the HPFP? If so, I suspect you cannot run without one. It is likely there to keep the fuel pressure very high (by restricting the volume), but I wonder if a small upsize to the orifice could be made. That would allow the setup to flow more fuel but still function as intended. Hopefully someone more knowledgeable about this setup will chime in.
Joshinator99 is online now   Reply With Quote
Old 05-13-2019, 10:31 AM   #35
TJay74
No, this orifice is on the inlet side of the HPFP.
Old 05-13-2019, 11:00 AM   #36
JANNETTYRACING
JANNETTYRACING's Avatar
We carry the line with no orifice in stock and add them to all of our builds in house as they might need a little tweaking to get them to fit.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 07-01-2019, 02:27 AM   #37
ADstranger
Drives: Chevy corvette
Anyone tried upping the voltage through the tune with good results?
ADstranger is offline   Reply With Quote
Old 07-01-2019, 08:27 AM   #38
JANNETTYRACING
We do that in conjunction with the JMS but it will never provide the additional fuel a JMS does.
Old 07-03-2019, 03:26 PM   #39
ADstranger
Will the extra voltage reduce the life of the pump? Also, what power level can the JMS support, 93 oct??
Old 07-03-2019, 04:39 PM   #40
JANNETTYRACING
Absolutely NOT.
That depends on what pump and injectors we are talking about,
Old 07-06-2019, 06:46 AM   #41
ADstranger
Absolutely NOT.
Would you say all available BAPs are of the same quality? JMS, MSD and the KB ? Durability and ease of dialing in??
Old 07-08-2019, 09:22 AM   #42
JANNETTYRACING
We feel the JMS is far superior to others, the reason why we choose to sell them and use them in all of our builds.
Ted.
