Old 08-16-2018, 03:16 PM   #29
Silverwing
Drives: Yellow 2018 SS
Originally Posted by NW-99SS View Post
Best of luck proving a filter device with a built in check valve can be the cause of any damage to the engine whatsoever...PCV oil into an intake causes an engine to burn dirtier air, so I would gladly argue with the EPA as well.
I was actually told that my old 5th gen needed a timing chain cover reseal because the heat of Florida combined with the "increased internal pressure" due to the catch can I installed caused my timing chain cover to leak oil a little.
I have no idea if any of that's true or not. But I couldn't hire a lawyer to argue, they voided my warranty because of it.
So it can and does happen.
Silverwing is offline   Reply With Quote
Old 08-16-2018, 03:37 PM   #30
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
I have elite X2 dual outlet plus elite clean side. I don't care about the warranty and it work well in my opinion.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 08-16-2018, 04:44 PM   #31
Nsxmatt
Drives: 2017 Camaro
Once you alter a emission control device to not work as designed, they don't need to prove anything to deny coverage.
Nsxmatt is offline   Reply With Quote
Old 08-16-2018, 05:11 PM   #32
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
That's not how warranty laws work - they bluffed both of you.
1. They would have to prove that your catch can caused any added pressure to the crankcase - until they do, the warranty cannot be voided.
2. Warranty laws specifically state that yes, the manufacturer denying warranty must prove that the non-OEM device caused the failure they are claiming wasn't a result of something else.
Last - Mighty Mouse runs a check valve and a breather for these reasons. I believe both them and Elite will also stand up against any denied warranty claims.
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 08-17-2018, 11:19 AM   #33
Nsxmatt
Drives: 2017 Camaro
I've worked in service for over 22 years and have overseen tens of thousands of warranty claims. I'm quite aware what can and can't be covered. You are modifying a emission control device which by law is illegal. At that point there is not any burden of proof needed by a manufacturer to deny coverage. It even says it clearly in most every warranty booklet sold with any new car that if you modify an emission component, that part of the warranty will be waived. You can argue all you want but nobody here is ever going to fight a warranty denial. You'd spend tens of thousands of dollars and still end up loosing.
Old 08-17-2018, 03:33 PM   #34
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Not that hard to pop off any one of these CC before having to debate the BS warranty stuff folks...
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 08-17-2018, 04:48 PM   #35
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
U should run one. I had them on most of my sports cars but this car in particular being DI is prone to build up on the valves. Decreasing oil mist thru the manifold will reduce build up over time
Joey Soul is offline   Reply With Quote
Old 08-17-2018, 06:44 PM   #36
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
My take is, GM would have put one in if it really needed it. That being said, I don't have one and don't want to void my warranty so I won't be getting one either.
zr1chris is offline   Reply With Quote
Old 08-17-2018, 08:56 PM   #37
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Do you realize how easy it is to take a CatchCan on and off? I don’t care what anybody says regarding GM engineers! If you think these motors don’t have build up go talk to any custom shop that has a reputation & ask about motors with 20k miles they do H/C/I on and have them show you...
I saw one 2018 LT motor with less than 20k miles and was very surprised!
If you still think it’s a waste after than then it’s no biggie :0)
Old 08-17-2018, 09:03 PM   #38
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Catch can or bust! PERIOD! Anyone who says otherwise just isn't thinking right. Oil going through your intake is never a good thing.
All the best,
Jared
JDP Sales is offline   Reply With Quote
Old 08-18-2018, 12:13 AM   #39
ramairroughneck
Drives: 2018 Camaro SS
Oil has been going through my intake for my whole driving career. I’ve had a couple cars over 200k miles and one to 300k. Seen multiple LT1 cylinder head intake ports looking just fine and multiple post of DI Audi’s and Nissans looking not so good to put the scare out there. I’d say they are definitely worth it if you sell catch cans. If you have to pay a ridicules price just to have a clean intake then I don’t see the point. I’ll bet there are other parts of my car that are pretty dirty as well. I don’t feel I need the attaboy for showing I spent $300+ to catch 3 oz of a gasoline water oil mix on here or in some group on Facebook but kudos to the salesman and the buyers that do.
ramairroughneck is offline   Reply With Quote
Old 08-18-2018, 12:49 AM   #40
JonD
JonD's Avatar
Drives: 2018 SS 1LE
You get to claim your not wasting money while others get to be proud of the money they spend on a hobby protecting their fun.
Heaven forbid anyone make assumptions about things people choose to do
Old 08-18-2018, 01:10 AM   #41
ramairroughneck
I know. Like the one a few post back where I wasn’t thinking right. Lol
Old 08-18-2018, 02:34 AM   #42
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I installed the Elite 2X, but if I had known what a trainwreck the instructions and parts were, I probably would have passed it up. Hands-down worst instructions ever (as in no instructions, you get to guess a lot) and missing parts. Not a great solution, even though the can appears to be quality.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
