Old 08-05-2018, 10:37 AM   #29
Alain
Alain's Avatar
Is it a pain in the ass to install this thing?
Does the system need to be drained in order to do the install? I could take a Harley Davidson apart with my eyes closed but when it comes to cars I’m still apprehensively learning.
2018 ZL1 1LE/Red hot
Old 08-05-2018, 10:52 AM   #30
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Well, I finally got around to installing the ADM reservoir kit. Pretty happy with the final result. I had a few hurdles along the way, but none were major or too difficult to deal with.
I had to buy a 5/8” long aluminum spacer to get the bracket mounted where it should be on my car. Then I had an issue with coolant seeping from the upper port on the tank, which was being caused by a molding line where the hose connects. I sanded it smooth and also installed a different clamp, and it’s now good. I was initially using a spring clamp that didn’t apply much tension, so that may have been a factor. If I’d cranked down the supplied worm clamp, I don’t think it would have leaked.
It looks factory installed and definitely self-bleeds the system. It’s the highest point in the intercooler circuit, which I don’t think is the case with some of the other tank kits out there. The only thing I don’t like is the fact that it’s above the header. Seems like it could absorb heat there, but IAT2s look good so far.
BMWM.D. is offline   Reply With Quote
Old 08-05-2018, 11:09 AM   #31
ADM PERFORMANCE
Drives: Anything I want
Future kits - spacer added
We will add this spacer to all future kits. This is the first we have seen of this but are taking action.
Thanks
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 08-05-2018, 11:11 AM   #32
ADM PERFORMANCE
Originally Posted by Boosted4life View Post
Anyone have the link to where I can get that?
https://lsa-conversion-store.myshopi...sivoir-upgrade
Old 08-05-2018, 02:01 PM   #33
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Thanks
Andy
High level of service and concern noted. Thanks Andy.
2018 ZL1 1LE sw/PDR
Old 08-05-2018, 03:47 PM   #34
No and No
Old 08-05-2018, 03:54 PM   #35
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
You’ll lose some coolant when you disconnect the hose on the pump. But no need to drain the system. You’ll definitely want to pick up some coolant for the install though.
Old 08-05-2018, 04:19 PM   #36
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Thanks
Andy
That’s good to hear. It was just a simple 5/8” long, 3/4” diameter aluminum spacer with a 1/4” hole. Seemed to be about perfect for my car.
Old 08-05-2018, 06:40 PM   #37
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Can someone explain me why is this needed?
I supposed the left coolant reservoir was connected to the supercharger intercoolers too, as with the radiators.
Sorry, no supercharger culture here in Spain, just turbo...
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 08-05-2018, 07:39 PM   #38
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
I’m pretty sure it’s been explained somewhere in this thread, but no, there is no factory coolant reservoir for the intercooler circuit on the ZL1. It is not connected to the engine cooling system. As there is no reservoir, the fluid cannot be checked or topped off without special vacuum filling tools — and these cars have been known to get air in the system. Adding a reservoir with its level above the rest of the system makes it self-bleeding. So no more cavitation issues, and an easy way to top the fluid off.
Old 08-05-2018, 08:21 PM   #39
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
words of wisdom...👍
Old 08-05-2018, 09:01 PM   #40
Alain
Alain's Avatar
No and No
Thank you !!
What type of coolant do you boys recommend? I don’t even know what brand comes with the car.
This sealed the deal for me. Great explanation. Thank you.
Old 08-05-2018, 09:04 PM   #41
Alain
Alain's Avatar
Thanks
Andy
Do I need to type anything in the notes when I order to get the spacer needed? I know I can just run to the hardware store and get it but I’d rather not deal with humans in person unless I absolutely need to. Hahahaha
Old 08-05-2018, 09:09 PM   #42
Stephen12ZL1
Drives: '21 ZLE A10
use dexcool 50/50 available at every store that sells auto parts
