#29 | |
![]() Drives: 18 Black ZL1-1LE Join Date: Jun 2017
#30 |
Soon as she has a little break in mileage , Im guessing the engine does not need 1500 mi break in I think its more for the clutch and rear end and tranny but I could be wrong
#31 |
Drive fast, take chances.
Drives: 69 Z/28, 85 SS Monte, 01 2500HD Join Date: Jun 2017
I had mine wrapped same as yours for the same reason. It is a blast to track and the wrap makes it easy to clean up after. The wheels will take a beating from tracking, the hot rubber, brake dust, and grit will scratch them quickly. I have heard that ceramic coating works well to minimize this. I am going to pull the trigger on a second set of rims this winter to have a dedicated track set, I think the wheels really set the car apart from all others (like the wing doesen't
)Nice lookin ride
18' ZL1 1LE, Mosaic Blk, PDR, CF Trim, CF Fuel, TM TB, CAI Elite Carbon Series
#32 | |
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Any comparisons in the handling department. I already know it rides much stiffer, but how does it feel damping wise, sharpness wise, etc compared to the standard ZL1 with magnetic dampers.
Does it feel that much more sharp and precise? I am going to be adding the ZL1 1LE solid rear bushing kit on my SS 1LE and wondering how much of a difference it makes in feel to have the rear-end hard mounted to the chassis. Cheers
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#34 | |
Larry, listed below, in order of importance, are the items I would recommend. Use the coupon code FS6FS when you check out on our website, it will save you 6% and get you free shipping in the lower 48 states. Let me know if you have any further questions. BK063 Rear Cradle Bushing Lock Out Kit TCA059 Lower Trailing Arm, non-adjustable w/Poly bushing UTCA058 Upper Trailing Arm, non-adjustable w/Poly bushing UTCA061 Upper Control Arm, non-adjustable w/Poly bushing SB052 Adjustable Front and Rear Sway Bars ELK015 Adjustable Sway Bar End links SP364 Front Lowering Springs, Performance Version minimum drop SP043 Rear Lowering Springs, Performance Version 1" drop Best Regards, Frank Steadman Sales Technician BMR Suspension 813-986-9302 frank@bmrsuspension.com |
#35 |
Got car back on Friday Mike and his crew did a great job on the Xpel whole car wrap .
I also pulled the stock 1LE wheels and tires and will use them exclusively for track work, I added the BC Forged wheels and Michelin 4S tires for street duty |
