#29 |
![]() Drives: 2020 chevrolet camaro 2SS Join Date: Feb 2023
I'm getting ready to do an oil change and rear diff fluid change. I'm going with ULTRA1 PLUS 75W90 full synthetic API GL-5 for LSD rearends. I'll let you know how my 2020 2SS likes it. Oh, and I'm going with Mobile 1 supercar 0W40 full synthetic for the oil change.
#30 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I changed my transmission and diff. for first time at 37k miles. Used gm oils. Got a pump at harbor freight for $6.
#31 |
Diff Fluid
I use ULTRA1 PLUS 75W90 GL5 in my diff.
#32 |
![]() Drives: 22 Convertible V8 LT1 Join Date: Feb 2019
https://www.amazon.com/gp/product/B008BZS6J8/
is 10-4034 Dexron LS 75W-90 Gear Oil the correct fluid for my M6 LT1 Vert?
I bought my first 6-Speed convertible Camaro in November 2018 and now drive a Hot Red V8 LT1 M6.
My Windows Sticker: https://cws.gm.com/vs-cws/vehshop/v2...FE3D78N0129849 |
#33 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#34 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
I do not like that the maintenance section of the manual for my '23 says "See Dealer" for differential fluid spec.
From what I read, synthetic 75w90 with LSD modifier is the correct spec for a '23 1SS M6? The capacity seems quite low (~1.2 quarts?) so I'm planning on an early change. |
#35 |
![]() Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
22 SS1LE 6MT here
I changed around 1500 miles Thinking to change again at 12000 miles Should I warm up the car / fluid before changing or are you guys changing cold? |
#36 | |
Moderator
#37 |
Why would you wait 12,000 miles to replace 2L of oil and a half hour of your time for the component that has to transfer your engine horsepower to your wheels at an abrupt underload 90° angle, Just curious?
#38 |
It seems like overkill to be changing it at 12k miles? Isn't the spec around 45k miles? I changed it out during the break in period at around 1500 miles.
#39 |
I think 40 -45k is good if not abused as in track use . I did my first tranny , diff. change at 37. I am at 70 k now and every thing is good. I bet most Chevy trucks used for towing don't get the care most Camaros get.
#40 |
I use ULTRA 1 75w90 in my 2020 Camaro 2SS. Try it, you'll like it !
#41 |
I use the ULTRA1 PLUS 75w90 diff fluid, it exceeds the specs for diff fluid in my 2020 Camaro 2SS.
#42 |
![]() Drives: Camaro SS Join Date: Sep 2025
Is anyone else running 75W90 Mobil 1 Synthetic Gear Lubricant LS ?
It has GL5 rating & friction modifiers Thanks Hary |
