Old 06-21-2018, 02:31 PM   #29
TJay74
Originally Posted by JANNETTYRACING View Post
The D1SC is a big supercharger and it needs big bypass to eliminate surging and light throttle.
The blower moves air based on Engine RPM but you are in control of the throttle blade opening.
You have a large amount of air backing up in front of the throttle blade but the blade is barely open, this is what causes the Slinky effect or Surge.
Move to the Race bypass or add a second bypass to the Drivers side or Hot side of the intercooler and your surging will go away.
I prefer to run 2 as it can have more volume than 1 large one.
On my YSI Camaro I run 2, 50mm Tial Q valves with 1.5 psi springs.
Ted.
Awesome Ted, thanks for the info. I am actually in communication with Procharger now to see about getting the Race valve and the flange sent to me and then I guess I will tear the nose off and have my local welder do the work. Hopefully only down for a day or so.
Old 06-21-2018, 10:04 PM   #30
oldman
Drives: SS 6 speed of course
interested in plumbing a second valve in, actually welding it onto the pre-intercooler side hard pipe looks like the easiest place to put it. Thoughts?
Old 06-22-2018, 08:20 AM   #31
Chevy71
Drives: 2016 2SS
I'm thinking the same way you are. If I have to take the front of the car of and do some fab work, I may just add a hot side valve as well so I can be done with that. I'm also considering selling my car at the same time, so my work on the car is some what in limbo.
Chevy71 is offline   Reply With Quote
Old 06-22-2018, 09:17 AM   #32
oldman
This is off topic but I have to pass smog and there are two monitors that are stuck on evap and EGR/ VVT dunno, I'll trouble shoot each one, heck I don't think the car even has an EGR right? So I do have a cam with a limiter, will this cause the monitor to be stuck on? The evap as far as I can tell is a simple solenoid bolted to the intake and one plastic line to a hardline on the firewall. I don't see how this can be messed up, supercharger related? dunno
Old 06-22-2018, 11:19 AM   #33
Drsagacity
Drsagacity's Avatar
Pray it is so slight, I don't notice really and I have the 103mm TB and MSD intake. Oh, I did not tell you I went crazy and purchased a D1X with 4.5 pulley it will have the same boost as the P1SC but when I drop in the forged engine I can do some fun pulley like 3.85.... I did not want you all to pick on my "small" head unit... LOL.
The D1 is a beast. Had one on my Vette and I was running 780whp...we had planned on upping boost or adding a 100shot...but I needed to change. Gonna be sick. Congrats!
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 06-22-2018, 11:29 AM   #34
oldman
yeah, I going to run the 4.5 pulley till I get the forged pistons into the car. I should could put them in... oh well it is a hobby.
Old 06-23-2018, 09:49 AM   #35
JANNETTYRACING
JANNETTYRACING's Avatar
PERFECT
www.jannettyracing.com
email tedj@jannettyracing.com
Old 06-23-2018, 09:50 AM   #36
JANNETTYRACING
Won't pass EGR without VVT working.
EGR is done Via Cam timing.
Old 06-23-2018, 03:06 PM   #37
oldman
Yep that is what I thought too, Luck for me EGT / VVT are the same monitor and I can have one monitor "not ready", the only other option is to take it to west Texas and use my brother's address. Austin = California in case people don't know.
