#29 | |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
https://www.camaro6.com/forums/member.php?u=87996
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
#30 | |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
#31 |
+1
2018 ZL1 1LE sw/PDR
#32 |
HYPER SS
here is an ok shot of where the "L" bracket is located.
Ordered: 1/15/2016
#33 |
Thanks!
Is that an Elite bracket or did you fabricate it?
2018 ZL1 1LE sw/PDR
#34 |
Dyno Show Queen LOL
The Magnusson SS setup is not like the ZL1, the valley plate PCV is not vented into the bottom of the blower.. Its angled and comes with a line that's longer to connect to the valley cover to behind the TB..
50 bucks or more of the zl1 system is the PCV adapter that doesn't have the hole in the shaft that's letting the oil go up in to the blower from that nipple on top of the valley cover. I get the oil catch part but what have you done or should be done especially modified cars making more boost that pressure has to go some where.. If its a closed system great but now that I've add 3 lbs more of boost or the people running bigger blowers are they running a catch can sytstem with a breather.. And yes the MM can are not just nipples they have one valves in them and when you shut off your motor you can see it vent oil fumes. At least I did on my 5th gen. but I was running a draft system on it. I was venting pressure and catching oil.
#35 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
Yes, you never want to vent. vent/Draft is technology first used at the beginning of the automobile and was little changed until the mid 1960's when the PCV system was mandated Federally to reduce ground water pollution from the dirty oil dripping from cars. What was an unintended result was these same engines, using same oils, were now lasting 2-3 times as long as before proper crankcase evacuation and it took a few years for the industry to discover the PCV system was also removing the damage and wear causing compounds that enter all engines as blow-by before it could settle and mix with the oil, so the main cause of wear and failure was "accidentally" discovered.
The E2 and E2-X series Catch Cans provides full time evacuation using 2 separate crankcase evacuation suction sources so there is no comparison of the 2. Then we look at the effectiveness to separate and trap the damaging compounds not allowing them to be pulled through and still ingested. The patented internal design of the E2-X is approximately 95% efficient at stopping these VS app 30% with the other (anyone can conduct the test to see this in person), so if your goal is to stop the offending compounds from being ingested, there is also no comparison as the difference is huge. We pull suction on the crankcase with the dual valve systems full time so pressure cannot build in the first place (unless a breach in the piston/ring/cylinder seal is present) Finally, we maintain an emissions compliant closed system as regulations require for highway use (except NOT CARB cert for CA yet), so you have antiquated and ineffective separation vs the most effective on the market period. Not a claim we make lightly as many independent people have tested and validated themselves. |
#36 | |
Dyno Show Queen LOL
I'm not sure what to get your or MMS.. According to his description when you make more boost his can vent yours is closed.. That makes me think I would need to use some type of breather and your system vs his can that can vent so I don't have a bunch leaks like on my 5th gen when I had a closed system and a blower. When I went Twin turbo and pulled the motor I had little leaks every where so I made sure on the Twin setup when I got the 416 built I got a can that vented never had an oil leak again of any porting and I was running a lot more boost w the turbos. Is this true or not.. No one is doubting you can catches oil but what about modded cars making more boost? How can you get rid of the pressure build up from a 650 flywheel car to a car now w 800 rwhp car?
#37 |
HYPER SS
That's the one they provided me. They supplied me with the "L" bracket and a flat bracket as an option. For me, this was the most feasible.
Ordered: 1/15/2016
#38 | |
![]() Drives: 2018 ZL1 Vert A10 Join Date: Jul 2017
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ 2013 X5D 2005 STI 2001 2.5 RS Previous cars in chronological order 2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta |
#39 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Simply put, more boost = more vacuum.
#40 |
Thanks again.
2018 ZL1 1LE sw/PDR
#41 | |
![]() ![]() Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
It doesn't say can only or kit? just Camaro LT4 ZL1 does it come with everything? What is check valve? (included in the kit, not in the can only) Tx |
#42 |
Dyno Show Queen LOL
I emailed MMS I'm going w a better setup.. closed is good but just as thought both are closed but one can relieve pressure. .
my systems of course can operate closed loop. 99% of what i sell operates this way (i sell cans lots of functions depending on what the customer comes wanting and needing) BUT my draft and pcv models *what a funny name 'pcv' for a can that is said not able to run a pcv system?? lol!** run in both closed and open loop depending on crankcase pressure.* opens when needed and closed otherwise.* these models are what come in my 'mild' and 'wild' complete kits. this pressure equalizing availability is maximum effectiveness for crank flow stability, and the way my product works is unique to the industry, up to 1500hp capacity per can. elite blatantly copied my lt4 pcv adapter and even used still clips from that z06 video posted in their own instructions (until i made them remove them). i had a correct setup for the lt4 available almost a year before they did, and that is even with them copying my part.. so you tell me who is 'leading' the technology. anyhow i have some history with them and the 'tracy lewis' conglomerate, do their catch cans work good for stock oil catching* YES just as good as mine actually. do they work good for high airflow control NO.* many reasons why. https://youtu.be/Jl70sRRpibk
