Old 05-23-2018, 12:04 PM   #29
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Blackfire.
NYJets12 is offline   Reply With Quote
Old 05-24-2018, 09:12 AM   #30
Atra
Drives: 16' 1SS M6
Originally Posted by KirkH View Post
There are so many variables: type of machine, RPMs, amount of pressure, pad type, number of passes.
I always say detailing is an art, not a science. I use M205 pretty often in my business and it hasn't failed me with a Makita PO5000C and flat foam.
Detailing is a CRAFT not an art-art is subjective. Results are NOT. You are correct though there are a lot of variables. I used D300 with Megs MF pad on a Torqx10fx.
Nightfall Grey 1SS 56F Black Bowties
Atra is offline   Reply With Quote
Old 05-25-2018, 10:17 AM   #31
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
So.
Slower. Smaller area .
Much better.
I guess the first time was so easy I underestimated the amount of damage to my paint after the second winter.
There are still some small scratches, I guess a little deeper.
I am ok with those...more so because I have my face pressed against the car at the right angle to see them.
Still have to throw on the Blackfire products..
I am happy.
Thanks guys
Old 05-25-2018, 02:34 PM   #32
Markoz28
Drives: 18 ZL1 nightfall grey A10
this was with a Megs wash and wax and then some CG butter wet wax. I think it looks treat for now but in the next few months I’ll do a light polish.
Markoz28 is offline   Reply With Quote
Old 05-25-2018, 03:28 PM   #33
KirkH
Re apply the Butter Wet Wax every time you wash. It looks great but doesn't last long. Also,it can be applied BEFORE drying the car. That's why it is called Butter WET Wax. They also have Cherry Wet Wax if you prefer cherry scent.
Old 05-25-2018, 03:35 PM   #34
Markoz28
Good idea!
I figured it didn’t last too long. I’ve been doing a coat every 2 weeks so far.
Once I’m confident in my polishing skills I’ll do correction, PL+, and Collinite. Just want it to really pop.
Old 05-31-2018, 09:19 PM   #35
kodiakk
kodiakk's Avatar
Drives: 2017 Camaro SS FIFTY
what is IPA and how do you use it
kodiakk is offline   Reply With Quote
Old 05-31-2018, 09:23 PM   #36
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
IPA is just the detailers term for the alcohol/water I told you about yesterday. It stands for isopropyl alcohol, it's put in a spray bottle usually a 25% alcohol/75% water mix. I told you for your front To mix it 50-50. But for normal detailing/ cleaning it's 25/75.
Where do you normally use it? Usually after polishing, to get the surface virgin clean to set up for the sealant/coating/wax.
See me use it here:
https://www.camaro6.com/forums/showt...highlight=Year
Old 05-31-2018, 09:38 PM   #37
kodiakk
kodiakk's Avatar
I am laughing a bit here Glen, Thanks again for the help. Just didn't want to miss anything.
