Old 05-24-2018, 01:10 PM   #29
Drsagacity
Drsagacity's Avatar
Originally Posted by DWR View Post
Hold up, Are you telling us that you are running around 900hp with stock internals on an LT1?!? If that's true it gives me a lot more confidence in these motors/ really makes me think the real "issue" is the crank seal/venting and piston ring gaps. I was already pretty confident that the piston ring gap was the true cause behind people popping ringlands... There are a ton of guys over at performancetrucks.net that have been running up to 1000hp on stock blocks/internals (well maybe spings and cam) once they filed down the rings a bit. Though those guys were the LS based motors when a 4.8 v8 can push 1000hp on stock internals once the rings are filed/ their cave point was around 600hp as well (prior to filing the rings).... Just makes me think....
He is...Laynlo is a trainwreck waiting to happen.
Kidding, I love giving him a hard time. He’s essentially running over 700rwhp on a stock car with the Magnuson, Upgraded fuel system and drag pack. Thing is he ran all last year at 670rwhp with just alky injection. Low 10’s wasn’t good enough so he pushes on. He’s so close to 9’s now that you can see the illness overcoming him.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-24-2018, 03:13 PM   #30
DWR
DWR's Avatar
Drives: 2018 Camaro SS 1LE
This makes me so happy. Is there anyone else that is running this high on stock internals?
Originally Posted by fastball View Post
Since 1967 kids all over America have bought the Camaro for the good old American way: loud and fun.
2007 Toyota Corolla S -- Traded
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled
2004 Silverado single cab 4.8l v-8 2wd -- Traded
2018 Camaro SS 1LE -- Current DD
1997 Jeep wrangler TJ sport — modded off-road toy/ camping
DWR is offline   Reply With Quote
Old 05-24-2018, 05:55 PM   #31
laynlo15
Drives: 2022 Lt1 A10
I don't think so, if they are they are crazier then me.
Old 05-24-2018, 07:12 PM   #32
Drsagacity
Drsagacity's Avatar
I think he has demonstrated if you are safe with your tune and you make sure to supply enough fuel, the stock LT1 can go a long way.
It’s also a testament to what the entry level Magnuson can do. . .just by changing pulleys.
TBD performance
Old 05-24-2018, 10:10 PM   #33
laynlo15
Man you are getting educated on the Maggie, I'll be calling you before long for info. Actually Russ has a pretty good back ground in racing. He is having fun with his new found power we added to his Vert. I know he has a bunch of stuff we need to do to his car in the future. Russ thanks for your input, yes I'm a little crazy but I'm 66 years old and I've been doing this a while and yes the tune makes all the difference in the world and I have to thank Mike (toohighpsi Pres. of Magnuson) for all my ventures in making hp. He's the best tuner I know and he's helped me build a killer ride out of a bad ass street car. I owe everything to him for my wicked SS. Thanks Mike and it helps me to pass along my info to other Maggie owners and I'll keep helping everyone I can to make as much hp as they want.
Old 05-24-2018, 10:56 PM   #34
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Jenetty has a customer that has been making 760whp sbe for 2yrs or so now. There is a gal on Facebook that has been 800whp for 20,000 miles and still going strong. These engines will handle some power with correct fueling. most blow up running the stock fuel system on edge.
Old 05-25-2018, 05:39 AM   #35
laynlo15
Pretty impressive for sure and those are big numbers.
Old 05-27-2018, 09:27 PM   #36
Drsagacity
Drsagacity's Avatar
I assume the cars you are referring to both have cams to support the fuel needed? I think it might be more fair to say Laynlo has the most for stock internals. Again, “because he’s crazy.”
TBD performance
Old 03-21-2019, 09:43 AM   #37
sal11585
Drives: 2017 Camaro SS 2ss Nightfall Gray
Can i just order a OEM LS3 crank seal and it will work no problem? I am about to have a blower installed and i want to bring them the seal to make sure a Ls3 one gets installed. Only going for mid 500s to the wheel but i want to make the car as reliable as possible
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels
Roto fab Biggulp CAI
Full paint correction with cquartz finest ceramic coating
Whipple 2.9
ARH Long tube headers with High flow cats
1le sway bars F&R
BMR Upper and lower trailing arms
Hurst short throw shifter
sal11585 is offline   Reply With Quote
Old 03-21-2019, 09:54 AM   #38
JANNETTYRACING
JANNETTYRACING's Avatar
https://jannettyracing.com/products/...ont-crank-seal
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-21-2019, 11:10 AM   #39
laynlo15
That and they are inferior. My front actually pushed out at 13 lbs and the rear 16 lbs. I may have originally stated that wrong now that I think back about it. My bad.
