Old 05-15-2018, 12:23 PM   #29
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
You said it ChevyRules! I can't understand it either but to each his own! I use Shell V-Power in my 2SS almost all the time. I had to use 87 in it one time because I was about to run out and that's all the Money Back had so I put in a few gallons. Like was said it had decreased performance and I had a slight valve ping on acceleration. A day later put 93 in it and no issues.
Old 05-15-2018, 04:07 PM   #30
HackSaw
HackSaw's Avatar
Drives: 2017 Camaro SS
anybody ever ran non ethanol pump gas Its not real easy to find
HackSaw is offline   Reply With Quote
Old 05-15-2018, 07:33 PM   #31
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
94 for me only. Found at most Petro Canada stations. Formerly only available at Sunoco stations. I paid 1.61/liter 2 days ago. Just to put it in perspective, 87 is 1.34/liter so quite a bit more. Don't care though its not my daily but also use it in my daily. Am I an idiot? Yes probably but I feel its worth it.
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 05-15-2018, 07:57 PM   #32
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Yes... it runs A LOT better, when comparing the same octane levels.
From what I'm told, they introduced e10 because they needed to add ethanol to the gas to get the octane levels back up from adding detergents and other non performance additives. Since the additives lowered the octane rating and ethanol has a high octane rating (which is why everyone likes to run it), it boosted the octane levels back up fairly inexpensively.
Which gave ethanol a bad rep because everyone noticed that stuff ran worse with e10 gas, compared to ethanol free gas, and people automatically assume it's the ethanol
Old 05-15-2018, 08:57 PM   #33
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
ran worse because of the water it absorbs correct? in unsealed systems like mowers and boats. When my dad was putting e10 in his mower and generator. I would have to go over and drain the float bowls. they would be full of water. Now he can get strait 91 non ethanol and hasnt had a problem scene. My brother runs E85 in his 09 Tahoe and says it runs better then 93. He is black bear tuned for 93 with headers and flex fuel
