Old 04-03-2018, 07:09 PM   #29
jspt46
jspt46's Avatar
Drives: ‘17 Camaro 2SS
If you want to do good at the drag strip you are going to want a set of 17' rear wheels with drag radials for the track. A bolt on SS with stock tires is going to have a tough time with even a stock SS with a tire on all but the most amazing prep. These cars hit hard out of the hole. Not easy to put all the power down without a tire.
Very true! Would a good DR fit on the stock rim? I realize it’s not ideal...
jspt46 is offline   Reply With Quote
Old 04-03-2018, 07:10 PM   #30
jspt46
jspt46's Avatar
Originally Posted by Snowblind View Post
Tuned with e85
Ported TB
Ported intake manifold
RotoFab CAI dry filter
180 T stat
Lightweight wheels and Mickey Thompson DR's
If you're lucky or good, you can run low 11's thru the factory exhaust manifolds and cats. That should max out the budget with those mods. Don't cheap out on the tuning, these cars are finicky and they run great when dialed in correctly.
Excellent and thank you. Just have to find a reputable tuner
Old 04-03-2018, 07:11 PM   #31
jspt46
jspt46's Avatar
Plans to drag? Or race?
You didn't say.
I would pass on the headers....that's an easy $1000 right there or more.
Rather buy some new rubber.
1/4mi only and I’m beginning to think the same thing
Old 04-03-2018, 07:12 PM   #32
jspt46
jspt46's Avatar
Originally Posted by AchiliesSS View Post
With 3.5k would you be interested in saving another 2k it would be worth it to procharge it even with the base components stg1 kit with the p1x and still make 150+whp with growing room and ability to be upgraded with intercooler and blowoff etc later. If you get the blower then later small stuff wont really matter cause you would need a fuel system and forged internals before hand so this is the best bang for buck cause all the bolt ons available wont net you what you can get here and when you get to that level you'll be 10k plus in it. Just food for thought brother.
That’s very interesting and def something to think about. Thanks man
Old 04-03-2018, 07:17 PM   #33
jspt46
jspt46's Avatar
Thanks to all for the input. I’ll be going with the Roto-Fab CAI, LT’s, cat delete & tune. I think with that and some good DR’s even on stock rims, I should get into the 11’s.
Thanks again guys for all your suggestions!
Old 04-03-2018, 07:41 PM   #34
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Check out Fasterproms in Tampa. They did my tune and I have a year and a half on it with zero issues. I run E85 from a RaceTrak pump nearly all the time. I didn't disable AFM, though, and I may do that if I decide to go headers and a street tune through them again.
Old 04-03-2018, 08:29 PM   #35
jspt46
jspt46's Avatar
Will def keep that in mind. We have a few decent tuners in Ocala that I plan to look into when the time comes
Old 04-03-2018, 09:11 PM   #36
ULTRAZLS1
ULTRAZLS1's Avatar
Mickey Thompson et street SS will be best on a 20. But they won’t last at all on a daily driver. Few thousand miles if youre lucky imo. nt555r will last a little longer but they are nothing special
Old 04-03-2018, 09:42 PM   #37
jspt46
jspt46's Avatar
Thanks Ultra. Back in the day, BFG made a decent DR. I’ll look into those as well
Old 04-03-2018, 09:45 PM   #38
jspt46
jspt46's Avatar
Anybody had any luck with the Nitto NT05?
Old 04-03-2018, 10:24 PM   #39
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The Nittos are a much better driving tire imo. I see Mickey's that need 12 oz plus weight to balance. I chased a vibration in my 4th gen for almost 2 years that ended up being a bad MT Dr. I'm pretty much done with them for a street car. However they do hook good...better then Nittos for sure
Old 04-03-2018, 10:37 PM   #40
ULTRAZLS1
ULTRAZLS1's Avatar
Yeah
I’m guessing the nitto nt05 r might be the best middle ground for him for daily driving, mileage and traction. Not sure what sizes they offer
Old 04-04-2018, 08:15 AM   #41
jspt46
jspt46's Avatar
Yeah
Thanks guys. They have the Nitto nt05 in discount tire direct at the stock rear tire size. Might be worth a try.
Old 04-04-2018, 10:45 AM   #42
ULTRAZLS1
ULTRAZLS1's Avatar
I believe a regular nt05 is a normal street tire. The R is a DR
