#29 |
![]() ![]() Drives: 2016 1SS Join Date: Jan 2016
I've just found another interesting option:
Nitto NT01 275/35/18 for $240 delivered. What do you guys think? square setup of 10"X4
1SS, Black, Black Wheels, A8, MRC, NPP
#30 |
![]() Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
I'm looking into an 18" Square setup, and keep seeing that a 10" wheel with 25mm offset with 5mm spacer up front works. I just wanted to verify: Is this true for a regular 1SS with MRC, with everything else stock (NO camber plates, no other mods)???
(I was already leaning towards running the Hankook RS4 in a 285/35R18, this thread has helped cement that idea). I'm currently running GM Recommended "Track" alignment, but may see if someone can squeak out a tiny bit more camber. Is it safe to assume that wheel size won't interfere with camber adjustments? |
#31 | |
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
I already have my 305/30 19" RS4's, just waiting on my 19x 10.5 et22 Apex wheels to arrive. |
#32 | ||
![]() Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
I'm running 18x10.5 +22 w/ 12mm spacer and have a few mm clearance to the shock tower (no grinding and max front camber). |
#33 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
^ Are you guys running longer studs with the spacers?
#34 |
#35 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Anyone able to fit a square set of 18x10 or 19x10 with tires mounted into their cars for swapping trackside? I imagine it's impossible with our trunk openings.
#36 |
Yep. Last season once I loaded all 4 18 x 10 wheels w/ 285/645 PZero slicks in my car along with a jack and tools. I believe I had one wheel/tire 1/2 in the trunk, 1/2 on the pass through, then 3 loaded in the back seat (folded down). The 285 width 18" was able to be loaded through the trunk.
#37 |
![]() Drives: 2017 Camro ss 1LE Join Date: Jul 2017
IS THERE ANY 18INCH set up that does not require spacers ?
#38 |
Depends on what your goals are. If you want a square setup and also want to go as wide as possible, I think you are going to need spacers. The compromise would be either spacers in the front or a lot of poke in the rear.
18x10 you need at least a +20 offset in the front to clear the shock. 18x10.5 you need at least a +10 offset in the front to clear. Both of those setups would have a decent amount of poke if run in the rear. If you don't care about a square setup or maximizing width then you can easily get an 18" setup that doesn't require spacers. |
