#29 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I think TexasFox missed the fact his car came with an LT4 (a la ZL1)...or he got one of those rare factory stock ringers we all dream about.
Mine certainly was not with a 12.8 best. ;-)
#30 | |
![]() Drives: Chevrolet Camaro Join Date: May 2020
So I DID the research, and I’ll go and experiment and see if a 5,000 RPM NLS is faster than me at redline modulating throttle by feel, and I’ll report back! But I’m here to stake my belief that there’s just no way a NLS at 5k can beat me!!! But I’ll report as soon as I find out. |
#31 | |
Ps ever since selling New Fords in 2001, and being North Texas Saleen Rep, I learned that you MUST educate your OBD II in how you want to drive! I drive EVERY one of my 3 NEW Mustangs, 2 NEW Camaro and NEW Silverado 1500 I4T like I stole them right off showroom floor, same with NEW KTM RC8R Race Spec and NEW Yamaha R1 that hit GPS verified 203 mph at COTA after midpipes and flash!!! |
#32 | |
To get the most out of straight line speed one needs to hold every gear and shift as close to red line as possible. I know our engines start to drop hp and tq before red line but when you factor in gear multiplication you will always put down more force at the wheels when you shift right at red line in the gear you are in versus shifting early to the next gear (even if you have passed peak hp/tq). Using NLS at that red line shift makes for a quicker/better shift into the next gear as it will hold rpm for that next gear. Good luck and have fun as you experiment with launches and shift points.
#33 | |
![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
#34 | ||
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
#35 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I don't think you're understanding the feature based on your post. I initiate the NLS shift at ~6400rpm and the feature works perfectly every time. Unless you're traction limited after the shift and trying to manage traction at that point, there's no way you can beat the torque response after the shift without using the feature. I personally would prefer the SS 1LE specific target RPM vs. the non-1LE like I have. Try it out both ways, but go to a real track for some actual times. Quote:
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#36 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
TexasFox seems to have left the party,. He's probably out buying a lot more NEW stuff!
Baby Blue
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
'18 1SS 1LE Black, PDR
#38 |
The Green Hornet
Drives: 2020 Rally Green 2SS 1LE Join Date: Apr 2019
Is there a reason why the SS LT1 and the 1LE have different target shift points?
XCMKZ4- 2020 Rally Green 2SS 1LE
1100-07/02/19 3100-07/04/19 | TPW 8/5 3400-7/29/19 3800-8/2/19 Built! 4300-8/5/19 4300-8/9/19 delivered to rail yard 4200-8/13/19 Shipped! 5000-8/19/19 6000-8/24/19 She's Home! |
#39 |
2020 Shadow Gray 2SS
NO reason, same drive train...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#40 |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I read in another thread that it is for optimizing straight line / drag racing acceleration (6400) vs. road course (5000) where you might be shifting while pulling lateral Gs in a corner and want to make sure the shift doesn't cause oversteer. Not sure if that is actually the reason or not.
#41 | |
Despite the same powertrain, there's definitely a reason for the difference, but Al did not elaborate when he provided technical details on the feature so all we can do is take educated guesses at why they might be different. I suspect the SS was geared for max performance in straight line so they wanted that additional inertia gained by the 6400rpm target during the shift when there's good traction (dragstrip), while on the SS 1LE the target is more in line with the engine speed of the next gear to ensure the chassis does not get upset on a road course where traction may not be as good as on a dragstrip. That's just a guess though and GM will probably never confirm their optimization strategy for the two cars.
#42 |
In the 1LE the lower target rpm is for improved stability.
Like posted, you don't want to initiate a shift at 5500 and have the rpm shoot to 6400 before shift up to a higher gear when chances are the car isn't going straight down the road.
| Tags |
| m6 tremec gear ratio ss 1le |
