Old 03-01-2018, 06:46 PM   #29
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Originally Posted by srcstc View Post
Thanks
Here’s a couple pics. Hope it helps!
ssmike is offline   Reply With Quote
Old 03-01-2018, 08:06 PM   #30
srcstc
Thanks for the pics! I think I see the problem. After seeing yours it looks like mine doesn't have anything there. Yours has metal contacts in there mine doesn't.
srcstc is offline   Reply With Quote
Old 03-01-2018, 08:17 PM   #31
ssmike
BL1ZZRD
ssmike's Avatar
Wow that’s weird!
Old 03-01-2018, 08:19 PM   #32
srcstc
Wow that’s weird!
Yes it is. We both have a 16 2SS. They should be the same.
Old 03-01-2018, 08:26 PM   #33
srcstc
I wonder if the relay in the socket next to that one has a ground I can tap into. Anyone know how to check for ground?
Old 03-01-2018, 08:43 PM   #34
ssmike
BL1ZZRD
ssmike's Avatar
Do you have a continuity tester or a vom (volt ohm meter)? Touch one lead to ground and the other to the contact. Should read close to 0 ohms for a good ground.
Old 03-01-2018, 08:46 PM   #35
srcstc
I have a multimeter. I'll check it for continuity. If it's not a ground is there any chance of shorting something out?
Old 03-02-2018, 07:07 AM   #36
ssmike
BL1ZZRD
ssmike's Avatar
You should be fine. Just make sure the ignition and accessories are off.
Old 03-02-2018, 07:56 AM   #37
Redlinez
Shifts under load
Redlinez's Avatar
I can't stand the throttle response reduction in track mode. I guess I should pull the fuse.
22 Suzuki GSX-S 1000GT blue
Old 03-19-2018, 11:52 AM   #38
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
I just tried this Mod on my 2017 ZL1. I do not have the metal contacts where the ground is either. Also where the wire comes out of the fuse tap pointing down in the picture I have a Squire relay (K6) See in red on Picture using the pic from the SS above) in that spot making it impossible to insert the fuse tap as shown. I tried it the other way, and it does not work. I am not sure if I put the white wire in the correct position, and even turning the fuse tap the other way it may not be seating correctly. I looked for a fuse tap with the wire mounted on the other side, no luck so far. If anyone is successful with this on a 6Gen ZL1 please post a situation.
FLYNNZL1 is offline   Reply With Quote
Old 03-19-2018, 12:10 PM   #39
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I meant to post this to the other thread you posted in a couple of days ago. You have the same problem I did but it's an easy fix. See this post/thread
http://www.camaro6.com/forums/showpo...4&postcount=28
Old 03-19-2018, 12:14 PM   #40
FLYNNZL1
Drives: Man
Thank you so much, you have no issues with your heated seats? That is where the box gets its power from I take it, the white wire powers the NPP when on correct?
Old 03-19-2018, 12:19 PM   #41
SuperSound
SuperSound's Avatar
No issues at all for almost a year. Correct, it is just powering the receiver on the box. The white wire completes the circuit to allow normal NPP functions when the box is in the On setting. Be sure to plug the white wire into the same side of the fuse terminal as in my pic.
Old 03-19-2018, 12:24 PM   #42
FLYNNZL1
Drives: Man
Awesome, it looks like there is no ground inside our version of the fuse box either. I tried doing it all inside the box, but outside seems cleaner and easier.
Thank you again.
