#29 | |||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The first video mentions 2 hours from start to finish, while the second video mentions 3-4hr. I would probably plan for 3-4 hours for a realistic time (even that seems optimistic to me if they are taking time and torquing everything to spec). It took me much longer to do that in my garage with no lift, but I was taking my time and trying to document everything.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#30 | |
Track testing the new Hurst shifter (shift to 3rd and 4th using no-lift shift feature).
In my haste to get the camera mounted before the run, I see now that I mounted it too low!
#31 |
![]() Drives: Hyper blue 1ss convertible 6 sp Join Date: May 2017
Yes sir love the Hurst shifter, I've purchased a black ball for the shifter honestly it should be an option! Love it though! Really enjoy 2-3, 4-5 gates much more precise now
#32 |
After driving with the Hurst shifter with stock knob for about a month now, one thing I've noticed is the shift effort is on the high side, particularly when shifting from in gear to neutral. This is no problem for racing, but a bit much for daily driver. Maybe I'm just picky, but I thought I'd try out the following solution.
What I did was buy a 2" shock extension (9/16-18 threads... $10) and used the Hurst white ball / stick that came with the shifter. This brings the shifter height up by 1.25" compared to stock, but gives excellent mechanical advantage. Shifts are still very precise and throw is still reduced from stock (see calcs below), but the shift effort is now much closer to stock. I want to drive with this setup for a little while before reinstalling the boot. This way if I don't like it I can easily swap back to the stock stick/knob setup. Here's my calculations on shift throw and % reduction.
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
would a 1.6lb shift knob make shifting easier? I have a TWM shift knob
#34 |
Good question. The stock knob i had been using is weighted. I’ll weigh it and get back to you.
#35 | |
Hurst, Question for you: Would there be an easy way to modify the lower end of the assembly below the fulcrum (ie. slightly shorten the end below the fulcrum) to provide a little more mechanical advantage without having to change the upper stick height?
#36 |
After experimenting with a couple different options (see posts above), I've determined the best setup is the Hurst shifter with stock knob. I think this is the best balance between crisp/precise shifting, shift effort, and appearance.
At some point I'd like to test out the SS 1LE shifter to see how it compares. If I get the opportunity to test that in the future, I'll post a comparison in this thread. Thanks again to the Hurst team for the shifter! I wonder when the upper stick for use with stock knob will be available to purchase?
#37 | |
![]() Drives: 1987 Buick Grand National Join Date: Mar 2016
#38 |
![]() ![]() ![]() ![]() Drives: CAMARO Join Date: Jan 2017
I wish the install wasn’t suck a bitch to do :(
#39 |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Its like headers. It looks worse than it really is
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
#40 |
did they list this product to purchase? i don't see it.
#41 |
Drives: 2016 Camaro SS Join Date: Nov 2015
This shifter has not come to market as of yet. But due to the overwhelming interest, I know that this design has not been put on the "back burner". As soon as any new information becomes available you will see it posted here on Camaro6 first!
- Jason @ Flowmaster |
#42 | |
![]() Drives: 2024 ZL1 M6, 1978 Beechcraft Baron Join Date: Jun 2018
I'd also like to see this product offered for the LGX M6. |
