Old 02-01-2018, 11:10 AM   #29
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Originally Posted by SSummit View Post
Double clutching is only necessary on transmissions without synchros, to match the engine speed to the gear speed.
The 'purists' would disagree and claim double-clutching ensures a smoother transition which it does, but I agree with you in terms of wear and tear. I learned to drive stick on my last car (2007 mazdaspeed 3) and 11 years (165k miles) later, the tranny shifts the same and the clutch still grabs like new. Hardly ever double-clutched (maybe only a couple times to try it), no syncro issues.
I'd double-clutch, but it's too much work for slightly smoother shifts. On the track, it might be worth the extra effort though.
torqueaddict is offline   Reply With Quote
Old 02-01-2018, 11:29 AM   #30
ctrlz
Double clutching is only necessary on transmissions without synchros, to match the engine speed to the gear speed. The synchros perform this job for you, double clutching may reduce wear on the synchros but honestly how often do they fail/wear out? Simple rev matching with a single clutch action is plenty.
Absolutely correct!
People shouldn't be taught to double clutch until they know what a layshaft is. And once you have that knowledge...
Old 02-01-2018, 11:31 AM   #31
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Originally Posted by ctrlz View Post
Absolutely correct!
There's no point or need to double clutch these. In reality most people shouldn't be taught it at all because they'll never have to use it
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 02-01-2018, 12:29 PM   #32
ctrlz
No truckers or farmers here?
Old 02-01-2018, 12:34 PM   #33
Dubchitts
Dubchitts's Avatar
I'm a trucker. I use the clutch when I'm stopped
"Spitfire" 427ci
