Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 01-26-2018, 06:52 PM   #29
Bhobbs
Bhobbs's Avatar
Originally Posted by FNxR3DNECK View Post
Who says it has to be that small? I know the main reason would be emissions but I think they will be able to manage the emissions enough to have a 6.0 or 6.2, just look at all the crazy emissions stuff they came up with for the new 2019 Silverado. Like someone else said the main problem is upon startup, I would bet they will be able to figure it out so that we can have a 6L, probably won't see another 7L though unfortunately.
No one said it has to be 5.5 liters but the issue with DOHC is, the more displacement, the much bigger the engine. The 6.2 LT1 is about the same size and weight as the 5.0 Coyote, despite the Coyote having smaller bore centers. DOHC is massive for the same displacement and they may not be able to physically fit a 6.2 liter DOHC V8 in the Camaro.
Old 01-26-2018, 07:05 PM   #30
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
It will fit with no problem....if a 90 degree DOHC 4.2 or 5.5 will fit then a 6.2 will fit since cubic inches has nothing to do with external dimensions of the V8 engines.
The question you need to ask yourself is if GM is working on a radically different V8 with exotic degrees with respect to see angles, just saying, this could be a clean sheet game changer engine family so any and everything is possible.
My money is on a 6.2 DOHC V8 with heads from the new engine family going into the mid-rear engined Corvette, but I'm probably wrong.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 01-26-2018, 07:24 PM   #31
Bhobbs
Bhobbs's Avatar
Of course displacement has to do with the external dimensions of the block. The reason Ford sticks with 5.0 liters is because the block is not capable of much more. The 5.2 Voodoo is literally the maximum displacement they can get from the current engine architecture.
The small block Chevy has 4.40" bore centers. and a deck height of 9.24". The Coyote has bore centers of 3.94" and a deck height of 8.97". That's a huge difference in usable block to increase displacement.
Old 01-26-2018, 10:46 PM   #32
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
A 4.8, 5.3, 6.0,6.2, and a 7.0 LS block fits in the same space. The difference is if the aftermarket offers a different block maybe but also various deck heights will make a difference.
Old 01-26-2018, 11:52 PM   #33
Bhobbs
Bhobbs's Avatar
And none of those are DOHC, which is the issue with DOHC.
It's apples to oranges.
Old 01-27-2018, 12:39 AM   #34
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
The LT6 and LT7 are 5.5L DOHC 32V engines.
The LT6 is the NA version of this:
C8 LT7 twin turbo hybrid - speculation puts combined hybrid hp near 1000hp.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-27-2018, 06:30 AM   #35
Smokin19
Drives: 19' ZL1 A10, w/pdr
I look at that pic and say to myself, "man I am glad I don't have all that crap under my hood". What a nightmare to work on. NA engines for me.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 01-27-2018, 07:51 AM   #36
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Why does it have to fit under the current hood?
A nice sexy little power bulge on the hood will be cool.
.....like the old cowl induction hoods.
Old 01-28-2018, 08:09 AM   #37
MrChrisLS3
Drives: 2018 1SS M6
Originally Posted by 2SSRS@Gen5diy View Post
If its the 5.5 you may lose torque, whats the old saying "There no replacement for displacement" that's why i was hoping for the SB4, with that motor you get good torque # and high RPM, But then there is gearing, by adding a 7th gear and going with 4.11 rear end you can make up some of that torque loss.
Yes, gearing can offset the torque loss, however it also reduces efficiency. So now we're losing speed at top end, and losing fuel efficiency as well. It's robbing Peter to pay Paul.
However, with sufficient compression and duel fuel injection combined with the right cam specs, it could be a fun engine in the car. I don't see anything near 600, much less 700 hp out of it, but if we're talking about a road course/autocross car 460 to 500 is plenty.
MrChrisLS3 is offline   Reply With Quote
Old 01-28-2018, 04:34 PM   #38
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Yes, if you dont make up for it with a 7 speed which will have a higher last gear.
2SSRS@Gen5diy is offline   Reply With Quote
Old 01-28-2018, 10:47 PM   #39
MrChrisLS3
Drives: 2018 1SS M6
Well, yeah, but realistically how often will it even see 7th gear? I've daily driven my M6 2011 SS for almost four years and have gone into 6th maybe a 1/2 dozen times.
Old 01-29-2018, 09:31 AM   #40
2SSRS@Gen5diy
I get that, but for the gas guzzler tax this helps out, can save you as much as $1500 on the price of the car.
Remember the videos of the new ZL1LE where at 75MPH in 6th your doing 2500RPM if it had a 7th your down to 1900RPM that help you keep it out of boost RPM and your gas miles improve, that brings your gas guzzler tax down.
Old 01-29-2018, 09:46 AM   #41
shaffe
Drives: 21 Bronco
Aren't DOHC also much wider than OHV engines of the same displacement?
Lets keep it simple. ..
Old 01-29-2018, 09:52 AM   #42
2SSRS@Gen5diy
In the old days they where wider, think in the old days valves where at 23 degrees and now there 1/2 that so the head is not as wide as in the past.
