#29 | |
![]() Drives: 2016 2SS A8 Join Date: Feb 2016
With tubing the lower the gauge the thicker, heavier, and also more durable it should prove to be to heat over time. Thickness 14ga = 0.083 16ga = 0.065 18ga = 0.049 A side note: the amount of room inside the tubing increases as the thickness decreases so it should flow more volume of air. Tubing ID 14ga = 1.834 16ga = 1.870 18ga = 1.902
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
The thicker the wall of the pipe, the less heat will transfer out of them. More heat staying in the pipe the more velocity, more power, low under hood temps, etc.
Less ticking noise. Just much more quality. That's what you want in a header as far as that goes Last edited by 6spdhyperblue; 01-19-2018 at 11:06 PM. |
#31 |
Speed Engineering has been around for a long time. They have been a Popular budget header for the 4th gen for years. And no this company is not going to put enough pressure on companies like Arh or Kooks to lower thier prices. You want cheap then China headers you will get....American made products cost more money.
#32 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Stainless Works has a division made in China called Stainless Power. People overprice the crap out of late model performance parts in general because folks are willing to pay $45,000 plus for a Camaro or Mustang, then turn around and pay $1500 for a catback.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#33 |
For the money on the header, I went with Kooks, but come now $179 3" exhaust all the way to the muffler is um cheap, and "quality" of the exhaust system is really not much of an issue is it? Note I like the idea they leave out the muffler as there is a quality debate to be had there.
#34 |
Hooker charges $130 for the crush pipe delete kits...
https://www.holley.com/products/exha.../705013126RHKR You can buy 3" from the header collector to muffler for $180 and it's a crush pipe/AFM delete for $50 more. You can save some cash by using Speed Engineering's mid pipes and spend more money on the headers or mufflers Hooker Mid pipes = 560 Texas Speed = 400 ((Don't think you can purchase the mid pipe separate.)) Borla = 695 ((It's 2.75"))
#35 |
Shifts under load
I look at those crushed pipes and can't help but think it chokes there, but I've read posts where folks said nothing to be gained with different piping as those are engineered to flow what's needed (included the physics involved with flow and volume etc) Maybe you'd see a gain on a modified engine. Not sure who's dyno numbers to believe......Hooker's shows the baseline several days after the modified one.
#36 |
For the mid pipes I'd call them premuffler crush pipes, nothing that some heat a slide hammer and a bit of brazing could fix. I call bunk on Hookers 12 HP gain for this fix.
#37 | |
Do I think the removal of the crimps is going to net us gain like Hooker's dyno sheet reads? No, but it should be worth a three to five ponys up top. If you are a DIY fella with a welder, you can buy some overpriced 2.75" pipe for $10 a foot.((what my local exhaust shop priced me.)) Buy a 3ft stick, do all the work your self. $30 for 3hp-ish. While you're under the car, delete the secondary cats, 3ft more, so $60 into it, not sure what the cat delete picks up, but I hear it helps the sound of the car a lot. So low ball, you pick up 6hp-ish, that's $10 to 1hp, no tune needed that is going to complement anything else you do to the car. If you find someone to buy the cats, you could recoupe all your dosh and maybe even make a dollar. Just my two cents worth of nonsense.
#38 |
Anyone who has contacted them happen to also ask if they'd do a group buy for Camaro6 members?
#39 | |
#40 |
![]() Drives: 2016 Camaro 2SS NGM Join Date: Jun 2014
YOU GUYS BLOW MY MIND BUY EXSPENSIVE RACE CAR AND PUT CHEAPEST HEADERS ON POSSIBLE SMH
#41 | |
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
#42 |
Haha nice
