Old 03-07-2019, 05:32 PM   #29
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
Originally Posted by carguy55 View Post
They need to make more wheels specifically for the Camaro so you don't have to use the hubcentric rings
You are right, we do indeed....and we are!
https://www.apexraceparts.com/blog/t...ecific-wheels/
We expect to have these on hand at the end of May
- Cory
Apex Wheels is offline   Reply With Quote
Old 03-13-2019, 06:36 PM   #30
Apex Wheels
Drives: Camaro Z28
Our friend Andy is back again with his 5th gen SS and Z/28 flares, this time showing off our upcoming Camaro specific wheels. These feature a 67.1mm centerbore for a perfect fit and a knurled bead to prevent tire slippage under extreme forces. Stay tuned for more info as we are nearing the launch of the introductory Group Buy!
19x11" ET11 with 305/30-19 Bridgestone RE71R tires up front, and 19x11" ET43 with the same 305/30-19 RE71R's in the rear.
- Cory
Old 03-21-2019, 06:35 PM   #31
Apex Wheels
Drives: Camaro Z28
More Camaro specific ARC-8 goodness coming at ya. 19x11" ET11 front, 19x11" ET43 rear, wrapped in 305/30-19 Bridgestone RE71R's at all four corners.
- Cory
Old 04-04-2019, 06:46 PM   #32
Apex Wheels
Drives: Camaro Z28
Check out this video highlighting our recent photo shoot with a 2018 ZL1 1LE, mounted with our 19x11" ET11 front and 19x11" ET43 rear, all wrapped in 305/30-19 Bridgestone RE71R tires.
- Cory
Old 04-10-2019, 02:58 PM   #33
1CEBITN
Drives: 2017 Camaro SS Vert w/2SS
On the following setup from your site it says direct fit:
Front: 19x10” ET20 with 285/35-19 tires
Rear: 19x11” ET43 with 325/30-19 tires
On my 2SS vert with MRC will the 325s in the back require wiring harness relocation (ARC-8 or EC-7)? The 20's do for anything over 305s so that's why I'm asking. Thanks!
1CEBITN is offline   Reply With Quote
Old 04-23-2019, 12:50 AM   #34
Apex Wheels
Drives: Camaro Z28
I personally haven't heard anything about that, but cannot confirm to be honest.
Old 04-23-2019, 12:51 AM   #35
Apex Wheels
Drives: Camaro Z28
Yunick Motorsports' SS 1LE looks sinister sitting on some 18" SM-10 wheels in Race Silver.
18x11" ET25 square
3/8" front spacer with ARP Studs
315/30-18 BFG Rival S Front
335/30-18 BFG Rival S Rear
- Cory
Old 05-06-2019, 06:21 PM   #36
Apex Wheels
Drives: Camaro Z28
Chip's ZL1 1LE was the perfect fit when we got our hands on the first 19x12" sample wheel. Check out the video our team whipped up to show off the 19x11" ET11 and 19x12" ET41 staggered setup, wrapped in the factory 1LE spec 305/325 Goodyear Supercar 3R tires.
- Cory
Old 05-11-2019, 02:44 PM   #37
Destroyer_1LE
Destroyer_1LE's Avatar
Drives: 2017 Camaro 1LE
Wheel Spec:
Front: Apex SM-10 18's 10.5 et22 with a 12mm spacer upfront with hub centric rings
Back: Apex SM-10 18's 10.5 et22 with hub centric ring
Tires:
Front and Back: Michelin Cup 2 Connects 295/30r18
You can also find more photos on my instagram @Destoryer_1LE
https://www.instagram.com/destroyer_1le/
I just realized I made a mistake in the video by saying 8mm hub centric spacer when its 12mm hub centric Spacer. When I say 3mm I really mean 5mm non hub centric spacer. Sorry for the mistake.
I put together a little video talking about the spec and fitment.
2017 Camaro SS 1LE
Instagram: @Destroyer_1LE
Sponsor: Tires: Michelin, Wrap: Protective Film Solutions, Wheels: APEX RACE PARTS
Destroyer_1LE is offline   Reply With Quote
Old 05-15-2019, 12:26 AM   #38
Apex Wheels
Drives: Camaro Z28
Jason's lowered SS 1LE is sitting pretty on another set of our Camaro specific 19" ARC-8 wheels, this time in a staggered setup.
19x10" ET20 front wrapped in 285/35-19 Bridgestone RE71R
19x11" ET43 rear wrapped in 305/30-19 Bridgestone RE71R
- Cory
Old 07-22-2019, 01:42 PM   #39
Apex Wheels
Drives: Camaro Z28
Patrick's SS 1LE was tearing up the track a few weeks ago on our SM-10 wheels. Check out the specs and photos below.
19x10.5" ET22 in Satin Black
5mm spacer up front
305/30/19 Hankook Ventus RS4 Tires
Hub centric ring
- Cory
Old 08-14-2019, 04:04 PM   #40
Apex Wheels
Drives: Camaro Z28
Gary put his SS 1LE in stealth mode with a complete XPEL Satin wrap and is rocking our direct fitzx ARC-8 wheels anthracite, 19x10" ET20 squared wrapped in 285/35-19 Michelin Pilot Sport 4S tires.
- Cory
Old 08-21-2019, 12:36 AM   #41
TEST DRyVer
TEST DRyVer's Avatar
Drives: 17 ZL1 6mt with PDR
Originally Posted by APEXRaceParts View Post
At this point there are no plans for 20" wheels, mainly because there is no need for them. The factory wheels are unnecessarily large. 19" wheels clear all of the brake kits out there, offer better/more tire options, and have less wieght than their 20" counterparts which results in better performance
Hey There! I have a 2017 ZL1 that I purchased 2 months ago. It's time for wheels. I am cross-shopping a few different brands and setups, one of them is yours. I'm also specifically shopping 19's as of recent, but I've come across a problem in finding tires in the sizes I'm looking for. Above you stated there are more options for tires in 19', but I'm finding the opposite. Please guide me in where I need to look. I would like to run a thicker sidewall, 35 series instead of 30. Ride quality and less rotational weight would be my main factors in considering 19's over 20's. In our cars it seems that you can't run a 35 Series tire without rubbing (at least for certain. Some were successful, some were not). Ideally, I'd pick up a set of your wheels in 19×10 in the front, and 19x11 in the rear. I'd like to run 285/35/19 tires in the front and 305/35/19 tires in the rear. When I look up that fitment on tirerack, the only tires that pop up are Michellin Cup 2's (great tires as I've had them in the past, but not what I'm looking for in my daily ZL1). I know you guys love your squared setup, but that's just not for me. I can see the reason for a squared setup on my wife's F30 335i (which I personally did not opt for squared when buying wheels and tires for her car), but I really don't like the idea of squared for a 6th Gen. Any idea on sizing options for tires, and proper fitment for wheels? The EC-7 would likely be my choice, although pricing could sway me to ARC-8.
Current Daily: 2017 ZL1 6mt in Black with PDR.
Esthetics: Nardo Grey wrap with original black accents throughout, complete Xpel ceramic coat, Diode Dynamics markers, Smoked GM tail & 3rd brake light, C7 Carbon 1LE style Spoiler in blk, ACS splash guards, blk'd out emblems. Variant Krypton wheels in Gloss black.
Performance: AWE Touring catback exhaust with resonator, Rotofab dry intake, TM throttle body, Kooks 1 7/8 Headers with Green Cats, Advanced Fuel Dynamics Flex Fuel kit with e50 blend and dyno tuned.
Current Family car (for the wifey): 2021 Audi SQ5
TEST DRyVer is offline   Reply With Quote
Old 09-11-2019, 11:37 AM   #42
Apex Wheels
Drives: Camaro Z28
Hello, thanks for the question! To clarify, the "more options" comment is in regards to performance tires in the 305/30-19 size. Bridgestone RE71R, Hankook RS4, Nitto NT01, Goodyear Supercar 3R, etc.
For someone such as yourself searching for more sidewall and ride comfort, 305/35-19 is the way to go but as you saw tire selection is quite limited. I would recommend the Nitto 555 G2 in this case.
