#29 | |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
So minus all the drama, what's the consensus recommendation for someone with a 2016 SS, running R88R's (285/30/20 on a 20x10 and 315/30/20 on a 20x11) that doesn't want to ruin their MRC shocks after a few months of driving? I know they've discontinued to the FE4 kit for 2016 MRC cars since they can't reflash the shocks. I started thinking about getting the springs and sway bars separately, but I think that may be put too much stress on the MRC. I'm currently thinking a sway bar upgrade may also do damage over time. I agree that all of these things are a designed to work together. Just going to a stickier tire alone is probably going to put more stress (probably not a lot) on my MRC I figure...just want to be smart about this. It's just a street car for me. Thanks
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
#30 | |
![]() Drives: 2017 Camaro SS Join Date: Sep 2017
FWIW though, I've switched over from the SS 1LE bar to the Hotchkis bar, which is significantly stiffer over my stock bar (40% stiffer over SS 1LE FSB and 70% stiffer over SS bar) and have huge improvements on my Non MRC car with Custom Valved Koni's that we made in an autocross environment. Keep in mind that I'm on stock 8.5"/9.5" wheels on RE71R with stock springs.
Jeff Wong
ESP Camaro |
#31 | |
FMPG
Ok thanks anyway for getting back to me. I've heard that the bars alone won't do much compared to the tuning, so i'm trying to find out if I can change our the suspension control module to a 2017 so I can then use the kit (and get the tuning).
#32 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
so does anyone know the OEM ZLE (ZL1 1LE) sway bar rates? I've searched but couldn't find that information anywhere
#33 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
ZLE (FEA) front bar is softer than FE3 front bar. I never updated my thread because of all the haters in here. I ended up running FE4 front bar with the FEA rear bar on full stiff. I never got an FE4 rear bar to compare to the FEA because the FEA rear was stiffer than the FE3 rear.
Now I run BMR adjustables, mid stiff front, full stiff rear. Definitely improved turn in and oversteerability with each change. I really like the stiff BMR bars for my driving style and my lap times showed. |
#34 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
#35 |
Weight, diameter, distance to mounting hole. I believe you and I were PMing about the bars and you were going to give me info on the FE4 rear bar, but I don't think you ever did.
#36 | |
https://www.camaro6.com/forums/showp...&postcount=124 Last edited by Mountain; 01-20-2020 at 04:47 PM. Reason: Check PM’s and I have no conversations with you. |
#37 | ||
I'm surprised to hear they actually use softer bars on ZLEs..i know the fact the Multimatics are way stiffer and adding those spherical bushings make it even stiffer but still find it interesting they opted for softer bars/stiffer struts method. Knowing they come with much more agressive compound tires and larger sizes Quote:
#38 | |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
#39 | |
It's hard to believe we don't have those specs in hand (ZLE bar rates). SS ve SS 1LE rates have been posted but not the ZLE apparently, oh well
#40 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
https://www.thatgmpartsguy.com/oem-p...JjaCBSZXN1bHRz
They seem to have taken the guess work out of this with this kit.
#41 | |
#42 | ||
FE4 = ZL1 & SS1LE FE3 = SS Quote:
