#29 |
Retired from Car mfrs....
The answer is in:
With a polisher, no need, by hand, yes IPA or eraser https://www.autogeekonline.net/forum...35#post1541735 Straight from carpro. 2 - Do I have to use Eraser between Essence and CQuartz? If your using Essence by machine and you wait until the vehicle is finished then you can apply Reload or CQuartz after you finish the vehicle starting in the same direction you polished. If you want to be ultra safe you can still Eraser but in our testings to date we have not seen any failure when we skipped Eraser. If your using Essence by hand then we recommend you use Eraser before coating. |
#30 |
Definitely not a waste, this combination is the best thing I’ve seen. I think the Eraser step is not necessary unless you applied by hand or in a hurry to apply a coating. What I’ve learned from this is generally good idea to wait a while for the Essence to fully cure and I believe this depends on the climate.
#31 |
Not sure why this minor wrinkle would make this stuff a “waste”?
Forums can be so extreme.... |
#32 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
#33 | |
Agreed, we ALL use too much of a product, most of the time. |
#34 |
For the bunch of times I have polished with Essence, waited a short period of time to apply Reload, I have never had any bonding issues or the Reload not holding up over time. I get 6 months out of an application for both of my vehicles. Sometimes people take things too literal or overthink things. I am going to continue doing what I have been doing and enjoy the gloss, durability, and ease of cleaning with these products.
#35 |
LOL...I sometimes still can't wrap my head around the less is more thing!
#36 | |
From the Ageek thread: “You can apply directly after with reload or hydro2 without eraser or ipa. If you use a polisher to apply essence. How do you polish with essence? They have a little special step to polish it. Recommendation are that you have the speed on 2-3 on the polisher. And when essence clears you go up to speed 4 to induse heat to activate the resins and work it for 2-3 minutes. Of course you can do it at you use to. But to get the most out of essence I think this is a good way to do it. There is alot of opinions hos to do it. I take this recommendation from carpro UK on how to work with it.” |
#37 | |
#38 | |
This is how you apply Essence, and how much product to use.
Meguiars DMF finishing pads are great with it. 1 slow pass, product will be clear, go over the edges, wipe off the little residue that remains, go to next section. You can't do this with a standard finishing polish. It takes 4-6 section passes with them to get it to flash (turn clear). Essence also leaves a layer of protection that lasts up to a year. My car is not garaged and it lasted a year, and would have gone longer. I had to do two APC washes to remove it all after a year. I do top it with Reload, and do a Hydrofoam wash every 3 months. The DMF pad creates a bit more heat than a foam pad. Unless your in the rare occasion to have an unusual clearcoat that doesn't like Essence, you wont have any hazing with it. When your done with the panel, check it with a light. If you have a spot that looks hazy, this is just excess product. Make a quick pass over the spot (don't add more product) and it's gone.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. Last edited by Joe M 2012 2SS; 11-28-2017 at 09:34 PM. |
#39 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
now it seems much more clear. Thanks all for the research, and its a good thing I asked! I'll look forward to when the products get here and the time comes to reflect back on this thread.
**what I meant as a waste was, wondering if I wasted my money on the incorrect product. didn't mean to have it being taken out of context.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
#40 | |
#41 | ||
![]() Drives: 2016 Camaro SS A8 Join Date: Apr 2016
#42 |
I use the Meguiars 5" DMF pad on my Rupes 21, I changed the backing plate from the 6" to the 5". Some people state that you cannot use the Rupes 5" backing plate with the Rupes 21, but that isn't true.
The machine is balanced by weight, and the 5" weighs exactly the same as the 6" one does. Kevin Brown (probably the best detailer in the world), has been doing it for a long time. He also invented a washer mod for the original Rupes 21, which keeps the pad spinning on curves, so I haven't had the need to try the new Mark II, since changing the backing plate and adding the KB washer mod. I'm sure it's a good machine though. If my original one ever goes bad, I'll get the newer version. Now I don't have the newer Mark II Rupes 21, so I don't know if the backing plates for it are able to be changed from 6" to 5". I also use the 3" Meg's DMF pads on my Rupes Mini. These pads will also work with a standard DA, just get the proper sized backing plate. Meguiar's actually makes a backing plate specific for these pads for a standard DA (they call them disc's instead of pads).
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. Last edited by Joe M 2012 2SS; 12-09-2017 at 02:05 PM. |
