#29 |
If you like that, you'll love this: To be fair the right number is my normal one
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#30 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
1,800 posts and the first time i've been called "troll". Guess I can check that off my bucket list.
+30MPG dang!!! Mostly highway I assume?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS H50 Join Date: Mar 2016
I was on the highway for both photos.
Heath
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
#32 |
![]() Drives: 2017 Camaro 1SS M6 Join Date: Jul 2017
It's my understanding that horsepower all comes from how much air and fuel you can burn, as an engine is essentially an air pump. You can increase power in several different ways, namely increasing RPM, larger displacement, higher flowing heads, camshaft etc. Whatever can get more air into the motor.
The main difference between the LT1 and the 3.7 aside from displacement is the valve train. The 3.7 is a DOHC, the 4 valve design has a lot more airflow available to it, which also allows you to not have to run as much lift, which gives you a more stable valve train. The LGX for example, only has a max lift in the .420" range. So, the increase in airflow coupled with the ability to spin the motor even higher leads to the higher horsepower per liter. However as others have mentioned, horsepower is not the only metric when designing an engine. Engines begin their lives on the drawing board. I'm sure GM had a laundry list of requirements for their new engine line, and the LT1 design met their new targeted horsepower, weight, fuel economy and cost requirements. |
#33 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
If you want to compare engines across configurations, use BMEP, BSFC, external size, and weight.
The HP/L thing is nice bench-racing but it's certainly not the whole picture.
#34 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I wonder how much parasitic loss there is in the LT1 say compared to the coyote for friction losses from the valvetrain?
Would also be interesting to see how much cost difference is. |
#35 |
![]() Drives: 600whp 2016 C63 AMG/ 2018 SS 1LE Join Date: Apr 2017
#36 |
![]() Drives: 2017 2SS Join Date: Oct 2017
"LT1 - so little HP for the liters?"
Not at all, the LT1 is producing radical power for a normally aspirated production small block. The LT1's power and torque levels exceed the best performance big blocks from Detroit's muscle car era. All this with outstanding efficiency and driveablitity. I am in awe what Chevrolet has produced with the LT1. As I look at the head design what I see is a modernized Boss 351 Cleveland Ford. The intake ports and canted valves scream Cleveland. All the vintage American V8's blocks are very similar, what really sets them apart are the heads. The Ford 351 4V Cleveland was the king of small blocks of yesteryear and what we see in the LT1 is the Cleveland brought into the modern era. I discussed this with a few of Chevrolet's engineers at the Chevrolet display at the Barrett Jackson show here in Vegas six weeks ago and they could not disagree with the head design similarities. Interesting the Ford is producing now a 5 liter v8 with monster breathing 4 valve heads and then they constrain it with small displacement. The Coyote still need to be revved into the stratosphere to make the hp the LT1 does at lower rpm's. All Ford needed to do was to modernize the Cleveland- like Chevrolet did. : ) ![]()
Last of the V8 Interceptors!
#37 |
![]() Drives: 2017 Camaro Join Date: Nov 2016
What engine building companies can do to one of these LT1's is what i would call "radical power" from a naturally aspirated engine. Totally reworked inside, with a similar overall weight and size, like Katech's Street Attack 427ci LT1, for example, which puts out 700hp and 620lbs of torque. And it comes with a warranty. So i understand where the OP is not all that impressed with the stock output of the LT1; It can be made stronger, but at much greater expense, and the fuel efficiency goes right out the window. The stock LT1 is the best compromise in cost, efficiency, power, weight, and size for a mass production vehicle with today's technology.
#38 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Weird, we have LT1 and LT4 engines making more than 175hp per liter
#39 | |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
![]() 455HP and 455lbs TQ and still get over 26mpg on the highway. Sounds pretty efficient for the power we get. Last edited by Marty McFlew; 11-29-2017 at 05:48 PM. Reason: d |
#40 |
Look at the performance 6 bangers out there making nowhere near the TQ of our cars and and the bodies are 3 or 400lbs lighter yet there MPG is not much better than our V8s.
#41 | |
#42 | |
