Old 03-22-2018, 10:31 PM   #29
laynlo15
Drives: 2022 Lt1 A10
VP MS109 race fuel, Meth/water injection
Old 03-23-2018, 06:54 AM   #30
parish8
Drives: 17 SS a8
Whoa, I missed this thread. That thing is ridiculously cool. The twin throttle body’s sticking out of the hood is sweet.
Old 03-23-2018, 07:16 PM   #31
laynlo15
Its bad ass as I saw it in person in February when I was there on a Team Shop tour. Its crazy sounding and had to be detuned to get it down the track at 950 rwhp. Went 9.60@152. When they get the new tire setup and can actually run with 1155 rwhp it should go 8.60s at close to 160.
Old 04-11-2018, 09:02 AM   #32
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Please tell me the under hood kit will have that same sweet whine? Or would it be possible at all to have the above hood kit on a street car?
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 04-11-2018, 09:47 AM   #33
laynlo15
I know they are working on it, the whine is another question. Maybe Mike can chime in on that. I usually talk to him once a week so I'll ask him and get back to you. The jack shaft series for drag racing has some killer sound to it. Doubt it will be anything like that, but would be awesome for sure.
Old 04-11-2018, 04:58 PM   #34
solobaric
solobaric's Avatar
Awesome. Thanks! Guess I could always have some kind of hood cowl fabbed up if I have to because I gotta have that whine.
2001 Ford Lightning
Old 04-12-2018, 10:30 PM   #35
toohighpsi
Drives: 2015 C7 Z06 M7
While this TVS2650 Camaro makes a lot of noise, the blower sound that most people are looking for is the 8th order "rotor passing frequency" noise. This is a pretty big no-no when designing SC systems for OEMs - but in our aftermarket world it's very desirable - up to a certain point.
The amplitude and frequency changes with rotor RPM, so the faster the SC is spinning the louder it gets. All TVS superchargers make pretty much this exact sound, but with the 2 open throttle bodies directly over the rotor inlet faces most of the noise makes it out of the SC instead of being controlled by reflection and sound absorbing materials. Take a listen to 6genmike's TVS2300 Heartbeat in the video below making over 1000HP.
https://youtu.be/ENWRODnhxYM
Sounds pretty familiar... Similarly, he's running a larger 103mm throttle body, directly connected to the MAF with an open air filter element allowing the noise to escape (and good airflow into the blower). You can also notice the blower starting to get quiet at the end of the run - an indication of the restriction of the throttle body on the engine.
We weren't able to reach the full power capability of the TVS2300 on this engine because of the 103mm throttle body being too small (there was almost 2psi pressure drop across the throttle at 7K RPM. But if we were able to use a large enough throttle body the scream from the SC (and engine power) would have increased all the way to redline.
We're hoping to have a larger throttle body solution for this TVS2300 on 6genmike's car once the engine is installed.
If you want your SC to make more noise, find ways to make it radiate. Replacing the OEM-like rubber elbow between the throttle and MAF with a thin wall plastic or aluminum tube will radiate more noise. Open air filter elements will help here as well. Finally get your fuel mods in place and hit the tuner shop to run a smaller pulley - you'll get sweet sounds from both ends of the car - SC scream up front with raging exhaust and roasting tires at the rear... I'm smiling just thinking about it!
Old 04-12-2018, 11:27 PM   #36
solobaric
solobaric's Avatar
Lol. Thanks for all the insight. Now when the 2650 is released will it have the option for the twin open throttle body setup just like the SEMA car? Or was that just for that car only. I want the 2650 to sound almost identical on my car as it does on the SEMA car.
2001 Ford Lightning
Old 04-27-2018, 03:07 PM   #37
laynlo15
The magnuson Camaro just ran 5.94@120 1/8 mile w/1.39 60ft Mike will post the slip later
