Old 06-12-2018, 05:16 PM   #29
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Just got my Quickjack last week, had the car up in the air last night just to try it out.
A little more than Race Ramps, but all four are off the ground.
'18 1SS 1LE Black, PDR
Old 06-12-2018, 05:21 PM   #30
Dave-ROR
Drives: A few
Which model? I've been considering buying a set.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 06-12-2018, 05:50 PM   #31
Boost Creep
Drives: '18 1SS 1LE
The 5000XL or whatever it's called.
5000 capacity and the extended length frame, 66".
Old 06-13-2018, 07:00 AM   #32
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Any issues getting the jack points to line up with the QuickJack? I have one as well and since it's not the extended version I had to get the extension rails. I can get the rubber blocks on my ZL1Addons jack points but it's real close to being on the edge like the jack are not long enough. I raised the car one time and it was very unnerving!
Gabhart is offline   Reply With Quote
Old 06-13-2018, 07:23 AM   #33
Boost Creep
Drives: '18 1SS 1LE
I use the front and rear pinch weld openings with ZL1addons bolt on lift pads. I have the rear pads as far forward as they will go, and the fronts as far back as they go, and they are both just within the quickjack lift plate. Both ZL1 pads are completely on the quickjack rubber blocks.
When I first put the ZL1 lift pads, the fronts were right in the middle of the opening. I measured before ordering, looked like the extended version would fit, and it was close. When I got the quickjack I saw the lift pads were too far apart, so I moved the fronts back as far as they would go.
I didn't want to use the "middle" openings in the pinch weld as I wanted the front as close to the engine weight as possible.
Old 06-14-2018, 06:30 AM   #34
Gabhart
Gabhart's Avatar
Pretty much the same as I am doing.
Old 06-14-2018, 09:35 AM   #35
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
I've used the above pictured circular pads with the slot cut in them many times. They're under $15 on Amazon.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 03-13-2019, 09:12 AM   #36
wintertopdown
Drives: 22 Convertible V8 LT1
Do I really need these zl1 pads or special ramps?? How do I simply jack the car to change oil without do-dads. Seems a bit over the top.
wintertopdown is offline   Reply With Quote
Old 03-13-2019, 02:33 PM   #37
Jimbeau11
Jimbeau11's Avatar
Drives: '18 Black SS 1LE; '01 Corvette Z06
I've been thinking about Quickjack. I'd love to see pics the next time you have the car off the ground.
Jimbeau11 is offline   Reply With Quote
Old 03-13-2019, 03:37 PM   #38
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
Technically, no. However, the location of the pinch weld/lift points is such that it is difficult to get a standard floor jack in there without damaging the lower body panels. You could use wooden blocks or even old hockey pucks if necessary, but then you are risking stability while you are under the car.
JD_ is offline   Reply With Quote
Old 03-13-2019, 05:32 PM   #39
Boost Creep
Drives: '18 1SS 1LE
I have an oil change coming soon and plan on doing the diff again and swapping out the trans fluid. I'll take some pics when it's up in the air.
Do you want to see where the ZL1 lift points and the Quickjack meet or just an overall pic to see how high the car goes up in the air?
Pics won't be great as my garage is so small it's like a glove for the car.
Old 03-13-2019, 08:08 PM   #40
wintertopdown
How about these? One on each side.
Old 03-13-2019, 09:52 PM   #41
Boost Creep
Drives: '18 1SS 1LE
People have folded their pinch welds with better jacks than those.
Old 03-14-2019, 12:34 AM   #42
s346k
s346k's Avatar
Drives: like an old lady
i used 2 piece race ramps. i bought the zl1 pads with set screws but i haven’t installed them yet.
note: the 2 piece 6’2” ramps will fit in the car.
