10-13-2018, 05:36 AM | #29 |
Every single one of them has DR's and a better 60' if you want specifics.
10-13-2018, 09:50 AM | #30 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
On top of that, I'm still 100% stock. No parts changed, removed, or modified. No tunes either. I'm not as fortunate as some, where warranty means nothing to them. A big out of warranty repair would put me in a bad predicament financially. Big Dave and myself even weighed our cars after our first pass together to verify our weights with one another. Based on all the data I've collected from the 50 or so 1/4 mile passes I've made, I was expecting to run 11.3s to possible 11.2s, but I actually surprised myself and ran a .1 better. If running those times in that heat doesn't prove 10s in cold air, I don't know what does.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
10-13-2018, 11:00 AM | #31 |
Drives: ZL1/335i Join Date: Apr 2014
From the rich AFR and throttle closures I was seeing when I was totally stock with only the Roto-Fab, I’d be a little surprised if I got any gains from it alone. I threw it on the dyno in that configuration, and it made a hair over 540 rwhp. Never did a baseline totally stock, so I don’t have any real data.
I feel like there was definitely more left in my 10.79 pass, though. I’m still shocked that I got the MPH I did with essentially just the Roto-Fab and headers given the DA that night. |
10-13-2018, 01:44 PM | #32 | |
10-13-2018, 03:06 PM | #33 | |
My fast list 1.8X 60' was at the Fest 7 with the Roto-Fab CAI. All the others ahead on the fast list have DRs and a lower 60' which made all the difference. We had good prep at Fest 7 too but I didn't get many runs and was on full air. My bone stock fast list time was 2.0 60' on horrible prep, but the trap times are almost identical which is another reason I don't put a lot of stock in the CAI being a huge bolt on item. We have a drag strip rental coming up next month Nov for the M6 so we will see how it does off the line. Not expecting much there. |
10-13-2018, 08:11 PM | #34 | |
Good luck at the track rental. Maybe you can top the stock 1LE list.
10-14-2018, 05:47 AM | #35 | |
If I can break in to the 11's with the 1LE I will be happy. Not sure which tires I will use. Stock Goodyears or Michelin PS4. I don't think either should drop me out of the bone stock category since the PS4 is not a DR. I am doing a before/after dyno with Roto-Fab and Catback. Hope to get the after done end of this month. |
10-14-2018, 06:53 PM | #36 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
You're at a huge disadvantage with the 1LE aero and the M6. Look at the number of M6 cars on the stock fast list. Unless you want to brag on this forum, the list is purely symbolic. The guy in the Hellcat lining up to your on DR doesn't care.
10-14-2018, 09:51 PM | #37 |
I think you need the tires your car comes with or its a bolt-on. I agree with your thinking. And I think taking the seats out also should put you on the bolton list.
10-15-2018, 06:05 AM | #38 |
That definitely would have helped. I'm on the list just moving down, but that's a good thing. Now I get a chance with the new car but will need to remove the big wing creating drag
10-15-2018, 10:48 AM | #39 |
Correct. Removing seats etc. is a weight reduction mod. The only time I've seen anyone get to keep their time on the stock list with a different tire was a switch to an all season tire with less grip and a higher tread wear rating. Even then they had to fight to stay on the stock list.
10-15-2018, 04:39 PM | #40 | |
10-15-2018, 07:30 PM | #41 |
aka BeastZL1
It's pretty simple. Run your car, post your slip, be honest about your mods. Obviously, the A10 has a huge advantage.
10-15-2018, 08:34 PM | #42 | |
