Old 07-18-2023, 09:39 PM   #29
2018blackss1le
Drives: 2018 chevy camaro ss 1le
I really need help with this one.... again. My car, 2018 ss 1le randomly goes into key learn mode. If I don't try and start the car in 2 days the battery is stone cold dead, where I can't even use the remote to unlock the doors. It was fine for 3 months and now it's doing this again. Originally turning off the wifi in the radio settings I thought fixed it but now I'm back to the same situation. I'm assuming I have a bad bcm or a bad ground. The stealership is no help. The keys work and keyless works, but when I push the start stop button it says key learn mode pending, only sometimes. Why is it going into key learn mode?
2018blackss1le is offline   Reply With Quote
Old 07-18-2023, 10:46 PM   #30
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Any aftermarket parts on the car? Tail lights, cameras, etc.? If so, put it back to stock as aftermarket crap are notorious for keeping the BCM awake when it should be asleep, killing the battery with parasitic drain.
Low voltage and dead batteries do all sorts of Bad_Things(TM) to the modules in the car. Charge it up and stick a tender on it.
Old 07-19-2023, 09:54 AM   #31
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Originally Posted by donaldp View Post
Just tried the second cup holder. Still nothing.
I took the leather top of the armrest off last night to resolve a creaking issue. I put some thick tape on part of the plastic pieces that were rubbing underneath the leather cover. Could this have anything to do with my issue?
Key Fob Battery completely dead Assuming you can't unlock the doors as well with the key fob.
If you can unlock the doors with the keyfob then its something else not sure what. Normally when I get that error its a dead key fob battery
Old 07-19-2023, 10:07 AM   #32
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Thanks. Car started now with remote in cup holder but would not start earlier with remote in the cup holder. Weird
Had that exact issue. Once it started and all was well, I took that remote and changed the battery.
jamala00 is offline   Reply With Quote
Old 07-19-2023, 10:37 AM   #33
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
2018blackss1le revived an old thread with his issue. Anyone answering posts prior to #29 are replying to the necrodead.
Old 07-19-2023, 02:46 PM   #34
wingchunsifu
wingchunsifu's Avatar
Drives: 2017 2SS A8, 2026 BMW X1 M35i
I've noticed when my key fob battery gets low this happens.
That's why I keep a fresh CR2032 battery in my glove compartment for a quick emergency swap out.
wingchunsifu is offline   Reply With Quote
Old 12-01-2023, 06:47 PM   #35
2018blackss1le
So allow me to answer my own post 9 months later. I'm not sure if me tapping in my radar detector into the overhead console caused this issue or if there was already an issue with this used car when I bought it, but the homelink garage door module is the issue. Pulling the luggage fuse compartment fuse f56( 5amp) fuse totally fixed the issue. I have recently reinstalled all pulled fuses with the homelink module unplugged and all is normal. I have since ordered a gen5diy radar plug for my uniden radar detector and it works fine even with the f56 fuse pulled. So again, maybe this was already an issue, but most likely user error, either way 9 months of cluelessness, everyday was a different scenario.
Old 12-01-2023, 06:52 PM   #36
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
What is Homelink? Oh yeah, that thing GM used to offer in the Camaro. What would we do without aftermarket after 2024?
Old 11-06-2025, 05:37 PM   #37
20204
Drives: Chevrolet Camaro 3LT
Originally Posted by 7WSM View Post
Looks like it might be a RCDRL Remote Control Door Lock Reciever problem. I wouldn't think what you did would have anything to do with it. There are 3 or 4 little antennas around the car that detects where that remote is. A antenna going out is pretty rare, I see RCDLRs go out more often. This would be a first on a Camaro that I have seen. But then again, it could be something else totally different.
where can i get this part and how do i install it? i recently had my camaro say the key fob was not detected, i inspected the fob inside and out for damage and replaced the battery but nothing worked. I then disconnected the cars battery and let it sit for 25 minutes then reconnected it and the key fob started working. when i did that it asked me to roll down the driver side window then the passenger side. this was yesterday. it was fine today up until it stopped detecting it again then right after it worked. so it stopped detecting the key then detected it. does anyone know what's going on?
20204 is offline   Reply With Quote
