Old 12-26-2017, 08:01 AM   #29
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would zero out the slip tables for all gears.
Old 12-26-2017, 05:27 PM   #30
parbreak
Drives: 2017 50th Camaro SS
OK. This is not a daily driver, but I do drive it on the street a good bit. Will zeroing out slip in all gears affect drive quality on the road? I'm new to this so if this is a stupid question, oh well, I'm trying to learn.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 12-26-2017, 10:54 PM   #31
KingLT1
KingLT1's Avatar
Nope...it will improve the driving experience all around significantly. Fwiw I am so much happier with the A8 after tuning. It's how it should have came from the dealership.
Old 12-28-2017, 02:15 PM   #32
parbreak
Alright sounds good. I'll have him zero out all the gears and see how she rides.
Old 12-28-2017, 05:22 PM   #33
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
that's what I hear many are doing lately. if I'm in the ballpark with the guess on the reason.... limiting the slip is like adding an old school shift kit.... in a sense its increasing the line pressure to reduce slippage?
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 12-30-2017, 11:04 PM   #34
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
from my understanding, it removes the slippage altogether which in turn keeps the line pressure from dropping to nothing.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 01-13-2018, 06:50 PM   #35
merlin803
merlin803's Avatar
Drives: 2016 Summit White Camaro 2SS
Probably a dumb question but why does changing the fluid stop the shuddering (albeit temporarily for some...)?
P.S. I had mine flushed a few weeks ago and so far the shuddering is gone.
merlin803 is offline   Reply With Quote
Old 01-13-2018, 07:24 PM   #36
Drives: 2016 camaro
New fluid usually has enough detergents in it to clean any debris or contamination off the clutches for full engagement.
Old 01-14-2018, 08:11 AM   #37
wrankin
Camaros Of Northwest Ohio
Drives: 2023 Red Hot 2SS 1LE
I was told the new fluid was synthetic and the part number backs that up. I also thought they mentioned a programming update but don't see that on the service record:
A CUSTOMER STATES ON LIGHT ACCELERATION FROM 55-60 MPH TRANSMISSION SEEMS TO HAVE A SHUDDER VIBRATION FEELING, NO CEL IS ON, ONLY HAPPENS WHEN HOT
CAUSE: SHUDDER
8480478 FLUSH AND DRAIN FLUIDS FOR TRANSMISSION SHAKE AND/OR SHUTTER REPAIR
220 WC
6 88865601 FLUID
12 19353429 FLUID
FC: 9090
PART#: 88865601
COUNT: 6
CLAIM TYPE: ZREG
AUTH CODE:
FLUSH AND DRAIN FLUIDS FOR TRANSMISSION SHAKE, REMOVED SHIFT CABLES BRACKETS TOWARD TRANSMISSION SOME REMOVED COOLER LINES COMPLETE COOLER SYSTEM PER BULLETIN REMOVED TRANS PAN DRAINED FLUID AND CLEANED RE-INSTALLED PAN. RE-FILLED TRANS WITH REVISED FLUID PER DOC ID 4526930 (16-NA-175) (TRANS FLUSH CODE E837F96 IS .6 AT 70 DEGREES) ROAD TESTED OK
So when I Google the two part numbers, the 88865601 is AC Delco Dexron VI Automatic Transmission Fluid, and the 19353429 ends up being a GM part number for Mobil 1 Synthetic LV ATF HP Automatic Transmission Fluid
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold)
2023 GMC Canyon Denali
2013 2SS / RS - AGM / Jet Black (sold)
1970 1/2 Z/28 Classic Copper / Tan (sold many years ago)
wrankin is offline   Reply With Quote
Old 01-14-2018, 02:45 PM   #38
Drives: 2016 camaro
CAUSE: SHUDDER
220 WC
6 88865601 FLUID
12 19353429 FLUID
FC: 9090
PART#: 88865601
COUNT: 6
CLAIM TYPE: ZREG
AUTH CODE:
Bill
the new stuff is synthetic, which has a better stability and can handle heat better. this is a given when using most synthetics vs conventional... its mobil 1 hp lv fluid.
however, the flush process, is more so a cleaning process. that's why its done 3 times and drained. I've already had the procedure done back in july 2017.
transmission fluid, however has a high level of detergents in it.
Old 01-15-2018, 08:05 AM   #39
wrankin
I went to Mobil 1's website and did not see the "Mobil 1 LV ATF HP fluid" that matches the GM part number 19353429. When I google "Mobil 1 LV ATF HP fluid" I find it at:
https://www.thelubricantstore.com
"It is approved and licensed by General Motors against DEXRON® HP ATF, making it a suitable replacement for a variety of GM parts, including GM Part 19355656."
So there seems to be several part numbers for GM ATF and also Mobil 1, so there must be some variation - it's pretty confusing.
The reason for my curiosity is I'd like to change the ATF to Mobil 1 synthetic on my recently purchased 2015 GMC Canyon and would like to use something that is approved by GM. It probably doesn't matter, but just want to make sure I'm covered.
Bill
Old 01-29-2018, 09:05 AM   #40
wrankin
Bill
It seems this is the new GM Part number for Mobil 1 Synthetic LV ATF HP Transmission Fluid: 19353429
Bill
Old 02-27-2018, 12:23 AM   #41
Redhot6
Redhot6's Avatar
Drives: 2016 red hot 2ss
Originally Posted by EFI Tuning View Post
You can use the old stock file with 3.6 if you need to flash back to stock. The backwards incompatibility is a bit of an annoyance. I wish they would update 3.6 to handle 3.7 opening and flashing.
Keep solid backups!
hey I just purchased my hp pro software last week it arrived today .even though I have no freakin clue what most of this stuff means I'm going to learn it lol.i tried to find the tcc slip tables but I wasn't sure what anything was .if you could point me in the right direction I would be very appreciate
Redhot6 is offline   Reply With Quote
Old 02-27-2018, 02:48 AM   #42
KonigWolf
Drives: 2016 2SS A8
I take no responsibility for any harm or weird sh!t that might happen to your car. Proceed with caution. Back up your original stock tune file. Also be aware that soon as you write a tune to your car, the warranty is pretty much voided.
Step 1: Contact HpTuners to gain access to version 3.7 BETA. ((Only 3.7 Beta has access to the AC and DoD slip tables.))
Step 2: Read your entire tune file with the 3.7 Beta version. ((You don't need to waste time with FSCM, its bottom read.))
Step 3: Save your stock tune file somewhere safe. Make a copy of it, and edit that file.
Step 4: Trans >> Auto TCC >> TCC Desired Slip.
Step 5: Zero out all the TCC Desired Slip tables for each gear. ((AC and DoD))
Step 6: Write the calibration for the TCM.
Step 7: Test drive.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
