Old 12-03-2017, 11:08 PM   #29
Bowty2SS
Bowty2SS's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Eyefixstuff View Post
Right... but he said stock internals. And I figured a cammed motor, especially on one of these cars would not be considered stock internals.
My B. Should have specified SBE....
Bowty2SS is offline   Reply With Quote
Old 12-04-2017, 07:09 AM   #30
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by Bowty2SS View Post
I guess it is all tuner opinion. There are daily driven lt1's with stock internals and stock fueling with procharger and meth running over 800rwhp that have over 20k miles on them with zero issues. Very confusing
They are relying solely on the Meth system anything above 580 RWHP.
Yes I can install a 1000 HP combo in my car drive it back and forth to work every day, and take it on vacations and never have a problem.
On the other hand if you race it every weekend be prepared to fix it.
The saying goes, race it, break it, fix it, repeat.
It is all a matter of how much you use that power.
Whether you have 400 hp or 2000 HP it only takes about 60 HP to drive 70 miles an hour on flat ground.
Hope this clears things up for you.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-04-2017, 05:52 PM   #31
Bowty2SS
Bowty2SS's Avatar
Ted.
Thanks Ted! My plans is only a weekend roll racer. I may PM you about a setup when I’m ready to buy my setup for Procharger.
Old 12-05-2017, 07:20 AM   #32
JANNETTYRACING
You are welcome email me any time with questions. tedj@jannettyracing.com
Ted.
Old 01-31-2018, 01:29 PM   #33
JANNETTYRACING
Great package bump for discussion.
Old 02-26-2018, 10:02 PM   #34
Drsagacity
Drsagacity's Avatar
Just off the dyno 2016 Camaro m6 convertable.
JRE Heartbeat Street Brawler package.
Magnuson Heartbeat supercharger.
85 mm pulley
Gates Green belt.
ZR-1 3 bar map sensor.
LTR6IX-11 plugs
LT-4 injection pump
LT-4 injectors
ZL-1 in tank pump
Dynatech LT header w supercats
JRE custom tuning.
93 octane pump gas.
Perfectly flat AFR.
600 RWHP 578 RWTQ.
I will try and get a dyno sheet posted having trouble exporting the image.
Video of the 2nd dyno pull, finished up on the 5th pull with results above. https://www.facebook.com/jannettyrac...5143945974091/
Ted.
I think this is what I am looking for. If I ran this setup, then in my next phase, I would add a cam and forged pistons. Thinking I would only run 550rwhp until forged internals are added. Am I missing something?
What is the cost for the fuel system as you outlined it? Do you have a package deal?
Old 02-27-2018, 08:55 AM   #35
JANNETTYRACING
This recipe is solid and I am totally comfortable at this power level on 93 octane, likely closer to 580 RWHP on 91 octane.
There is nothing missing from this recipe, but you can certainly add your own spices.
Ted.
Old 02-28-2018, 03:40 PM   #36
Deadi9mm
Drives: 1969 Camao 2007 Silverado
Is that with stock throttle body and CAI
Deadi9mm is offline   Reply With Quote
Old 02-28-2018, 04:01 PM   #37
JANNETTYRACING
Rotofab stock TB.
Old 03-01-2018, 06:46 AM   #38
Calubi
Drives: 2017 1SS 1LE
How well would a set up like this handle HPDE sessions? Would you be concerned about heat soak?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 03-01-2018, 06:55 AM   #39
JANNETTYRACING
I would not have the least bit concern.
Ted.
