#29 | |
![]() Drives: 2017 Summit White ZL1 M6 Join Date: May 2017
So the Chevy dealership by you will be built by 2019 and have an allocation ? |
#30 |
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Bump, going to "interview" my two local dealerships today about this recall and how, specifically, they will service my car if I bring it in for this. I'm sooooo scarred to bring my car to a dealer for service at all. My car stays immaculately clean and under a cover on the charger at home. Dealerships are a cluster and I'm nervous about scratches etc.
LMcgrew79, they don't use a machine to flush at all? If that's the case, I may just buy the fluid and change it at my buddies shop myself using your instructions you so kindly provided. |
#31 |
![]() Drives: Lexus, ZL1 1LE, Ducati, Suzuki, Join Date: Jul 2017
Makes me glad I bought a 6 speed manual
#32 |
#33 | |
Drives: 2013 GB GT Join Date: Mar 2016
#34 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
Can you post the entire bulletin? I'd like to see the procedure -- mainly the temperature where the fluid should be checked. The guy who had the engineers involved with his car mentioned 190-210 degrees. The older 8 speeds recommend doing it at 95-113, so big difference. I can't find any official documents on the A10, so maybe this will clear it up.
#35 | |
The temp for the ZL1 trans check is 209*f |
#36 | |
#37 |
![]() Drives: 2017 ZL1 silver A10 Join Date: Jul 2017
I feel like my A10 shifts way smoother and better when fully heated up. In these coolers months it takes quite a while to get up to normal operating temp.
#38 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
That's been my observation too, glad to hear I'm not the only one who thinks so. Once the A10 is warm it shifts like silk.
#39 | |
The instructions are basically: Get trans up to 209* Open drain/fill plug (it’s the same plug) Let any fluid that comes out drain until it stops.....if there is any to behind with. Replace plug. I’ll try to post pics of it if I get some time in the next couple days. The sheets are in my garage. And email :p |
#40 | |
Some other A10 owners have reported that they don't hear the whine I do, but I'm fairly sure I heard it on another ZL1 I fired up at the dealership, but I'm going to confirm that when I'm over there later this week. It's a high pitched gear whine type noise that can be heard at idle and just off idle (below ~1500 RPM). Almost reminds me of a 671 blower on an old small block. It doesn't really sound like a pump starving for fluid, but I know these A10s have a gear driven variable output pump, so maybe they sound different. Last edited by BMWM.D.; 10-17-2017 at 09:46 AM. |
#41 |
![]() ![]() Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
How do they know which one is overfilled?
They found the drunk dude who was in charge And the week he was sad? |
#42 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
I am now suffering from a harsh upshift from 3rd to 4th when in manual mode that someone started a thread on. When I first read that thread, I made the comment that mine wasn't doing it. I could feel the 4-3 downshift more than other gears, but it wasn't what I'd call harsh. Now I have it.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
