#29 |
Sarcasm loading --------
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#30 |
![]() Drives: 2017 50th Anniversary Camaro Join Date: Nov 2016
the reason it's doing this is because the purge valve is stuck open and allowing fuel to flow through the emmission system into the intake. this should set an Evap fault.
#31 | |
![]() ![]() ![]() Drives: A10 LT4 Join Date: Aug 2016
I actually wanted to ask back in March when I got it simply out of curiosity, but figured the internet safety police would beat me up too bad. ![]() I have 296,000 miles on the 6.0 3/4 Ton company with no fires. |
#32 | |
The purge valve can be tested by disconnecting the line from tank to valve and capping off. |
#33 |
"BEASTM*DE"
My AC cools the car quickly, so when refueling in hot weather I just let my windows down...Hell you're getting hot outside the car anyway...Just turn it off...
How much does gas cost in Dubai???
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
#34 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
I understand the heat issue. I live in southeast Texas, while we don't get to 130 typically, we see temps to 110 and combined with very high humidity, it's probably pretty close to what you see. Fill up early in the morning or late at night when it's only 100 or so, lol. |
#35 |
![]() Drives: Truck Join Date: Jun 2017
#36 | ||||
![]() Drives: 2017 ZL1 and 2016 GMC Sierra Denali Join Date: Jul 2010
Cost of fuel in Dubai is $ 2.40 for 98 Octane And thank you all for the feedback and suggestions and opinions. |
#37 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
People are free to do whatever they want with their cars. I've learned long ago arguing on the internet is just stupid.
If you want to leave your engine on while refusing, go ahead. Just be prepared for problems with your fuel/evap system and I'm glad you don't go to the gas station I go to. I WILL and HAVE called the attendant when I see someone fueling up with their engine running. Who will kindly advise them to shut off the engine or they'll cut the pump. |
#38 |
Fueling the car with engine running will not cause fuel or evap system problems unless a problem already exists.
#39 |
![]() Drives: 2020 1SS 1LE Join Date: Dec 2016
Tags |
gassing up, rough idling, shaking engine |
