Old 08-04-2017, 03:49 PM   #29
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Originally Posted by ADM PERFORMANCE View Post
No install manual.
No tune.
We have photos of the components going together for reference.
The rest of the parts are complete(bits,pieces,new center intercooler,precooler(uses original precoolers just like ctsv and zl1,comes with all the proper hoses)
Good to know that all parts are included in this upgrade ("Kit") to an LT1 engine.
In order to properly install these parts on the LT1, apart from pictures, how useful / relevant do you think it would be, to make use of the ZL1 / CTS-V OE GM Workshop manual?
Are any modifications / relocation of the stock LT1 wire harnesses, coolant elements, sensors, Etc. necessary, or is it pretty much a "plug & play" experience?
Tune: Would you be able to at least provide a file (that can be uploaded with an SCT, Diablo, Etc.) that you know from experience with these builds, that would be one that works well to a ~ 95% success rate for most of such upgrades, eliminating the necessity to dyno tune?
Old 08-04-2017, 07:27 PM   #30
LanceMagnum
Drives: C5 Corvette
This is exactly the route I'd like to take to get to the next step with my car. I'd really enjoy working on the install myself, even if it takes several days or more. An out-of-the-box tune would be great, but one just good enough so I could limp to the dyno shop is sufficient (can I just remove the drive belt for this purpose?)
The system is plenty for my daily driver, and the compact OEM look is a bonus in my book. If someone did an install thread (as has been done for some other systems) I don't think I could resist.
LanceMagnum is offline   Reply With Quote
Old 08-06-2017, 01:50 PM   #31
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
I think you can just wire open the bypass valve to run on the stock tune after install and drive gently. I've been following a guy on FB who just completed his and is awaiting his tune.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 08-06-2017, 05:11 PM   #32
Eldi Z
But there must be a file that should already work well for 95% of the requirements. If this setup has been tuned on a couple of LT1 engines before, then this should be good enough. Fine tuning at a later stage (Dyno or Street) logging I.E. with HP tuners would then be the "icing on the cake"
Old 08-07-2017, 05:21 AM   #33
ADM PERFORMANCE
Drives: Anything I want
The map sensor is the problem- if you leave the factory sensor in it will get you where your going . Its a bit of work to change once the kit is fully installed.
Just saying
ADM PERFORMANCE is offline   Reply With Quote
Old 08-07-2017, 12:18 PM   #34
Eldi Z
So what about a good base file that can get most of the people installing this setup going on the road safely? Before going to further fine-tune it...
Old 09-28-2017, 05:38 AM   #35
ADM PERFORMANCE
If you buy Hp tuners from us we can help you out as best as possible.
Old 09-28-2017, 07:45 AM   #36
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
What if you already own HP tuners from past vehicles? I mean I dont really want to buy it twice...
