#29 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: S O L D Join Date: Aug 2016
Changed it up this year, and bought "Flatstoppers" instead. I hate jacking this car up..........
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
#30 | |
Thank you Al Oppenheiser!
Put the stand right at the very end of the x-brace where it bolts to the rocker, not further in along the brace which can cause the brace to flex and bend at the mounting bracket stressing the x-brace-bracket-weld. |
#31 |
![]() Drives: Summit White 1LT RS I4 M6 Join Date: Oct 2016
I had my car on ZL1 Addons jackpoint for the past three days while I was waiting for a part. My Jack stands are similar to yours. No problem. They are steady and strong.
2016 1LT RS Summit White M6 10/2/2016 - 3 Miles on ODO - Delivered 11/1/2016 - All around light Black out kit from Phastek 11/15/2016 - OEM Splash guards and all weather mats from ShopChevyParts.com 12/16/16 - 977 Miles. Borla S-type Axleback Planned - CAI Injen, hood wrap, Sema rocker stripes, Sema trunk balckout, Caliper Paint, Reverse LED |
#32 | |
![]() Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
#33 |
![]() Drives: 2017 Fifty 2SS Convertible Join Date: Aug 2016
I am getting ready to change my wheels to MO17, found the ZL1 mag puck for gen6 doesn't work for my 2017 SS Vert. You have to buy the gen5 for the 2016-17 vert.
Those of you that use jack stands, do you lift from the pinch points and the jack stand fits along that weld or is there another place i can use my floor jack? Forgot to ask, should I buy 2 sets or will the entire side of the car lift from the front pinch weld? I have no intention of using jack stands, just want my all season tires.
2017 2SS 50th anniv. vert.
2017 Jeep Laredo Altitude 2018 MB GLE350 |
#34 | |
It will be obvious once you get under the car ... there's really only one pinch weld spot you can use near the front wheel to lift the entire side of the car. The SS should be stiff enough to lift both wheels on one side with only one jack. |
#35 | |
#36 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
#37 | |
Club F1FTY
#38 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
1+ 100% agreed. Never let you car on stands over the winter.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
#39 |
![]() Drives: 97 Z28 6MT, '12 G37 6MT Join Date: Sep 2012
I've read far too many threads on jacking this afternoon!!
With my current car (g37 sedan), raising the front/rear is effortless. Floor jack under K member under the engine then jack stands with slotted pucks at the pinch welds. For the rear, same except floor jack goes under the diff. Simple, easy, effortless. With the zl1/ss 1le this whole process is overly complicated. Some points indicate jacking under the diff is ok, others warn against it. Same with the front K member. Using a floor jack to raise one side (front and rear wheels at the same time) doesn't really seem like the right way to do this. So the question is, are there central safe points in the front and rear that can be used to raise 1/2 (front or rear) of the car at a time? |
#40 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
#41 | |
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
#42 |
Valid concern. I can see these zl1 protectors going on the middle position pinch weld (where a floor jack would be used), but not in between a jack stand and body. A slotted puck won't fit in between the jack stand and bodywork?
I made my own pucks a while back. Cut one puck in half then screwed both halves to a second puck with ~3/8" gap in between. Still, with a rwd car there should be central options to use which lift the front or rear half of the vehicle. Even our honda accord has dedicated 'jack' points in the body. There's a protruding piece up front under and forward of the engine. For the rear they say to jack under the tow hook. |
