Old 11-19-2018, 12:20 PM   #29
DarkFangz1100
Drives: 2016 Camaro SS
How are the fenders holding up to the added spacers?
DarkFangz1100 is offline   Reply With Quote
Old 11-19-2018, 12:21 PM   #30
burnningice
burnningice's Avatar
Drives: 2016 SS Mosaic Black
Just like day 1.
burnningice is offline   Reply With Quote
Old 11-19-2018, 07:17 PM   #31
DarkFangz1100
Originally Posted by burnningice View Post
Just like day 1.
Awesome, debating on the skirts for my car when I came across this article. Been putting it off for too long lol....it's a debate between OEM ZL1 skirts and ACS ZL1 to go with the rear brake vents
Old 11-19-2018, 07:28 PM   #32
burnningice
If you do decide to go with aftermarket items, hit me up. I'm the owner of overkillautogarage.com
Old 11-19-2018, 08:07 PM   #33
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Now replace rust prone plain steel washers w nylon spacer from same section of hardware store.
ing for grip.
http://www.motorsportsne.com/
Old 11-19-2018, 08:47 PM   #34
burnningice
Yes that, stainless steel or aluminum
Old 05-05-2019, 03:29 PM   #35
bereic
bereic's Avatar
Drives: Camaro SS 2018 Convertible
hello...
well done..
does someone maybe have some pictures showing closer the door and the fender ? Is the gap between them from the top to the bottom the same?
does someone know what the difference is between "Type 1" and "Type 2" ? (see attached picture).
and what about the other parts? Do i need to order them as well?
Sorry for my beginner english.. my native language is swiss german.. :-)
bereic is offline   Reply With Quote
Old 05-08-2019, 09:09 PM   #36
AdmAnt13
AdmAnt13's Avatar
Drives: '16 Red Hot 2SS M6 NPP
Hello!
I just completed this using this write up but instead used nylon washers and stainless bolts and nuts. Thank you for all the good info burningrice!
Bereic, I’ll try an post some pics of the gap at the fender and door from top to bottom.
It does close a tiny bit at the bottom, but nothing that bothers me.
Also, you need these part numbers only: 84491863 and 84491864.
All the rest you see came with them. The clips were pre mounted and the weather stripping came in the box.
'16 2SS, M6, Borla Atak
AdmAnt13 is offline   Reply With Quote
Old 05-09-2019, 01:49 AM   #37
bereic
bereic's Avatar
Thanks AdmAnt13
But how do you now have different part numbers?
Comparing the ZL1 and the SS in the online catalogue the Type 1 appears to be the normal skirts. As the part numbers with "Type 1" 23399023 and 23399024 are the same as on the SS selection.
The ZLI skirts are showing the numbers 84177432 and 84177431.
Thank you
Old 05-14-2019, 07:03 PM   #38
bereic
bereic's Avatar
Originally Posted by AdmAnt13 View Post
Hello!
hi.. did you have time to do some pictures?
And from where did you get your part numbers?
thank you
Old 05-14-2019, 07:21 PM   #39
AdmAnt13
AdmAnt13's Avatar
My part numbers came from the dealer. Those part number you have are old and have been superseded by the ones I gave you. They are the most updated part numbers. As far as pictures, I have them, but need to reduce the size before I upload to imgur to post.
Sorry for that delay. But believe me, it’s not noticeable. Take the plunge. You’ll be happy you did
Old 09-20-2019, 06:05 PM   #40
Trochoidal
Drives: 2017 Camaro 2SS A8
Hey AdamAnt, I looked for your pics and didn’t see where you posted them. Have you posted your results yet? I’d like to see how good it looks. Thank you!
Old 09-22-2019, 02:32 PM   #41
Coat-This
Drives: 2019 ZL1, M6
ZL1 Rocker Panels
Can you separate the mosaic black portion of the rocker from the painted quarter panel piece????
I just ran over something in mine and scratched up the underside of my rocker so I need the mosaic portion painted and was hoping to not bother with the body color portion.
Thanks
2019 ZL1 - M6
Mods - tbd
Coat-This is offline   Reply With Quote
