Old 06-26-2017, 12:09 AM   #29
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Originally Posted by bobby35ny View Post
The ZL1 is not such a short throw. WISH is was..:(
Never drove a 16SS M6 so I cant compare.
-Bobby
I went to a dealer and felt it. The gm one will be a big waste of money....it is such a small decrease in throw. Id spring for hurst or wait for mgw if they do theirs still.
I was bummed out by this because I like the look of the stock shifter. I can't stomach the hurst options. Mgw or none for me
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 06-26-2017, 08:12 AM   #30
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Agreed for the most part on Hurst. However if MGW doesn't move forward, I'd take a Hinson shifter, *if* they are going to make one.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 06-26-2017, 09:08 AM   #31
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Ugh, that sucks about the short throw. Oh well, more $ for barrels of ethanol until MGW is released. Hopefully they're able to improve on the stock shifter more than GM did. How much better was the Hurst the in your opinion?
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 06-26-2017, 10:49 AM   #32
Dubchitts
Dubchitts's Avatar
I haven't gotten to feel one yet. But gm claims only 6 or 7% on theirs, and I believe it. Hurst I think claims 40% but I'm not sure.
Maybe someone with a hurst can go feel a 1le and see how much the difference is between the two.
"Spitfire" 427ci
Old 06-26-2017, 10:51 AM   #33
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Oh wow, thanks, I didn't even know it was that subtle. I've heard a few people say they can't stomach the Hurst, but is that because of just the shift knob or is there another reason? I've seen a few sites that sell weighted replacements that may help.
Old 06-26-2017, 10:59 AM   #34
Dubchitts
Dubchitts's Avatar
I'm not a fan of the cue ball, not in this car at least. And the pistol grip isn't any better. Other than that I'm sure it performs excellent.
I've seen others run custom made knobs that look good, but that's probably easily another $100 on top of it all.
I'm gonna wait it out and see what options there are later. It's not like the standard shifter is that bad
"Spitfire" 427ci
Old 06-26-2017, 12:28 PM   #35
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
All good points...I'm with you on this. I thought the cue ball might feel good to shift with but I think they get very hot in the summer.
Old 06-26-2017, 12:54 PM   #36
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
I have a cue ball shifter in my kia koup and it fits the hand very nicely...have not noticed a problem in the heat; downside is how fast the colour faded (no uv resistance)
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 06-26-2017, 06:48 PM   #37
sschons74
sschons74's Avatar
Drives: 16 Camaro 1SS & 82 Silverado C10
I really like my Hurst. I got a SS ball from EPCO. Doesn't get hot, although stick can get hot from trans, not sun. I saw video of 1LE, and Hurst is way shorter throw. Only complaint is a little notchy going into 1st & 2nd. It does feel like 40% shorter throw. A little involved to install, but I think well worth it.
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB.
sschons74 is offline   Reply With Quote
Old 06-26-2017, 10:03 PM   #38
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Frankly, i think the stock m6 only needs stiffer bushings. The throw distance is still pretty fantastic especially considering it is stock.
I am interested in the GM short throw but for 6 or 7% shorter... that won't be worth 250 bucks+. I just need to check it out on the 1LEs.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 06-27-2017, 07:20 AM   #39
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
He lives! LOL
Old 06-27-2017, 08:23 AM   #40
F1FTY
Drives: 2018 ZL1
Yeah the throw difference isn't large but if you want a stiffer feel, it'll give you that. Can't wait to get mine and install it.
F1FTY is offline   Reply With Quote
Old 06-27-2017, 07:24 PM   #41
Dubchitts
Dubchitts's Avatar
When you say notch on 1&2, what do you mean? Does it not like to go into 2nd sometimes if you shift fast?
"Spitfire" 427ci
Old 06-28-2017, 06:04 AM   #42
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
We've got a little notchyness now when the car is cold between 1 and 2. I think it's normal when the car is cold but it should disappear pretty quickly after a few shifts. Does it not go away?
